NEED 350TPI w/ everything!!! ECM, wires, harness, pulleys, belts...ETC
Old Aug 5, 2010 | 01:57 AM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Transmission: 700R4 lookin for shift kit
Axle/Gears: 3.23???
In the next week or two I will be needing a 350tpi,like the title says. with everything. I am in CO
Old Aug 6, 2010 | 01:30 PM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Transmission: 700R4 2500 stall
Axle/Gears: 3.70 Moser 9in
Re: NEED 350TPI w/ everything!!! ECM, wires, harness, pulleys, belts...ETC
I have everything you need and the howell performance stand alone harness. How much are you looking to spend? I have the edelbrock 52mm TB and Bosch 24lb injectors on the TPI.
Old Aug 9, 2010 | 05:52 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I have a stock baseplate, stock runners, stock plenum, stock 24lb injectors, egr valve and solenoid. Yours for $150 plus shipping.
Old Aug 14, 2010 | 09:25 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
I have a distributor for a late 80's early 90's TPI car (Camaro, Firebird and Corvette. Not sure what else it was used on). Has new cap, rotor and module. No longer needed. $50 bucks
Old Aug 15, 2010 | 02:52 PM
1972-sselcamino's Avatar
Hello, I have a 1990 L98 tpi complete wiring,ecm,pulleys,ps pump,under drive,brackets and bolts. PS top end,heads up.
Old Aug 17, 2010 | 05:20 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
Sorry it took so long, but I dnt want to pay more then 1000 unless I have to. So how much are you willing to let it all go for?
Old Aug 17, 2010 | 05:21 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
I only want to spend 1000 so how much are you willing to let it go for?
Old Aug 20, 2010 | 03:44 PM
BLUE_IROC's Avatar
500 everything except pulleys alternator and needs a new oil pan. Located in nc.
Old Sep 10, 2010 | 07:32 PM
camarostylin's Avatar
hey there, I dont have the engine, but I have a COMPLETE 350 TPI system I can sell you. it's 100 dollars shipping, which is much cheaper than you'll spend trying to ship a whole engine. You can find any small block chevy with 87 or newer heads to put it on close to your place and pick it up for however much. the only part of the entire system that I don't have is the exhaust manifolds with the EGR lines coming off of it, but really you can run the EGR from any sort of manifolds that have provisions for it and I'm sure it would be fine.
it also comes with a used distributor, minus cap and rotor. the only part of the system I dont have is the distributor cover, and if you're interested in the setup I'd be willing to buy a new one online and have it shipped to your house.
total system is 350 plus shipping. it came off an 88 f-body with automatic transmission
LedZep
Aug 22, 2003 03:14 PM
BOTTLEDZ28
Apr 15, 2002 01:18 PM
nice3rdgenz
Oct 26, 2001 10:18 AM
Newbie Boy
Oct 4, 2000 08:10 AM
