3.27 9 Bolt rearend with disc
Old Sep 5, 2010 | 03:36 PM
jicaju's Avatar
Want a title? Post!
I need a 9 bolt with 3.27 gears and pbr style disc brakes.
Thanks Michael
Old Sep 8, 2010 | 05:27 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: 3.27 9 Bolt rearend with disc
where are you located?
Old Sep 8, 2010 | 08:31 AM
jicaju's Avatar
Want a title? Post!
North Carolina. I think what I need is the 1le style brakes. The calipers are aluminum and both calipers are on back side of rearend. Like on the TTA.
Thanks Michael
Old Sep 8, 2010 | 08:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Thanks Michael
Hey, Michael, welcome to TGO. FYI: Though called 1LE brakes, all 89-92 rear disc cars were equipped with what you describe. The 9-bolt, with the so-called 1LE brakes, was produced only in 89. With the correct backing plate, however, the brakes in question can be swapped onto an earlier 9-bolt (or 10-bolt for that matter).
JamesC
Old Sep 8, 2010 | 09:06 AM
jicaju's Avatar
Want a title? Post!
Thanks for the explanation. I have some wheels I would like to sell but site will not let me post in for sale section?
Thanks Michael
Old Sep 8, 2010 | 09:18 AM
JamesC's Avatar
https://www.thirdgen.org/forums/anno...php?f=118&a=95
JamesC
Old Sep 8, 2010 | 05:18 PM
Transmission: auto
ok i think i am too far away for you,
Old Sep 8, 2010 | 07:18 PM
jicaju's Avatar
Want a title? Post!
What do you have?
Old Sep 9, 2010 | 09:56 AM
MartinD's Avatar
Thanks Michael
I have a complete 3:27 posi disc out of an 87 IROC. $300
Old Sep 9, 2010 | 09:15 PM
jicaju's Avatar
Want a title? Post!
Are both calipers on backside of rearend?
Old Sep 9, 2010 | 09:25 PM
JamesC's Avatar
What Rear Disc Brakes Do I Have?
82-88 cars are equipped with iron, single-piston Delco-Moraine calipers and 10.5" rotors. In those years, the pass side caliper with its flex line is mounted in front of the axle, the drivers’ side with its hardline to the rear (I've heard that some early model cars, perhaps 82-83, have hardlines to both sides). The parking brake on these years adjusts the brakes, so use it frequently. If yours doesn't function correctly, take note of the "recall":
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
89-92 cars are equipped with alum, single-piston PBR calipers and 11.7" rotors (the so-called 1LE; however, all rear disc brake cars, 89-92, have them). Both calipers are mounted to the rear. All four-wheel disc cars, 82-92, are RPO J65.
For a picture, see my vbGarage in the lower left.
JamesC
Old Sep 10, 2010 | 04:40 AM
Transmission: auto
a 327 9bolt from a 92 gta
Old Sep 10, 2010 | 06:34 AM
jicaju's Avatar
Want a title? Post!
How many miles on rearend, does posi unit work. Could I get some pics, and how much? I just need rearend, brakes, brake plates, and brake lines,
Old Sep 13, 2010 | 08:18 PM
jicaju's Avatar
Want a title? Post!
ttt
Old Sep 14, 2010 | 09:39 PM
Abubaca's Avatar
I have a 3.27 rear set up for the PBR disc brakes. I'm working out a deal for another rear, and may or may NOT need to keep my actual calipers.
I'm in Greensboro/Jamestown NC.
Old Sep 15, 2010 | 04:39 AM
Transmission: auto
72k miles, i would think the posi works got the car with out motor or trans, its a complete rear end, caliper to caliper,
Old Sep 15, 2010 | 08:20 PM
jicaju's Avatar
Want a title? Post!
I'm in Winston-Salem NC. I don't know what kind of rearend your looking at but I have a Moser 9 inch ford I'm going to sell. Going back stock with my TTA. Maybe we can do some business. Give me a call at 336-682-3232
Thanks Michael
Old Sep 19, 2010 | 01:44 PM
jicaju's Avatar
Want a title? Post!
ttt
Old Sep 21, 2010 | 03:57 PM
travrock's Avatar
Car: 1991 Bird
Engine: Goodwrench 4bolt 357 bore vortec
Axle/Gears: 10 bolt posi disc w/3.23
did you sell the rear?
Old Sep 21, 2010 | 04:32 PM
jicaju's Avatar
Want a title? Post!
I am looking for a 9 bolt.
Old Sep 22, 2010 | 12:55 PM
MartinD's Avatar
The 9 bolt i have for sale has one caliper in front and one in back. Thanks
Old Sep 22, 2010 | 06:51 PM
jicaju's Avatar
Want a title? Post!
Not the brake style I am looking for. Thanks
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
carattini
Sep 10, 2015 07:46 AM
84 TA NV
Sep 6, 2015 08:02 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
