[KS] FOUND
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
FOUND
Title says it all I think. I would like to retain stock belt routing, but ditch the smog equipment on my 88 GTA. Let me know what you have, condition, and price shipped to 66216.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Smog pump delete for TPI serpentine setup
You can remove the pump and just get a different size belt. I have a belt with practically zero miles on it.
I did that a decade ago in my 89 TA, but it seems like the idler was damn near maxed out on travel.
Regardless, what is the P# on the belt you have?
Car: '90 RS
Engine: 377 LSX
Hmm, your idler should be fine with the correct belt size. The belt you use is actaully shorter than the stock length, this is assuming you remove the pump as opposed to using an AIR delte pulley. I don't remember the part number off hand but you should be able to get it with a quick search. It is K96XX, or along those lines.
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Maybe this will help? https://www.thirdgen.org/serpentine
I have seen the various methods for conquering the task, and am not entirely opposed to using a shorter belt for the time being.
Shifty, I assume you are selling the belt? PM me if so.
Thanks to you both.
Thanks to you both.
I have another car that I'm looking for this setup for. Anyone?
Longer belt worked fine on the IROC, but I'd like to have the delete pulley for the GTA.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Here is a thought , the export delete for the smog pump was discontinued years ago. The gates 38029 was the pulley they used on the delete bracket. The bearing is Bearing Bore I.D. 1 . The guide belt guide setup is still available gm or acdelco 10129569
Thanks for the reply. I got a good deal on a complete setup from another member, so this piece of the puzzle is taken care of for the time being.
Re: FOUND
haha. If I run across one, or don't end up using the one I have it's all yours.
Abubaca
Nov 5, 2016 12:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
