[NE] Vortec TPI Manifold Base/ecm
Car: 1985 Camaro Z28
We picked up a Vortec 350 from a Suburban. Lookin to put it in our Z28. Need the Vortec Base Manifold. Also a good 350 ECM
Car: 1989 friebird
Engine: V8 305
Transmission: after market automatic
Re: Vortec TPI Manifold Base/ecm
what type of vortec intake do you need, one for a throttle body or carb, i have a throttle body intake for $90 if you need that kind
I know someone here has jumped up to LS or newer and needs to unload the VORTEC TPI Manifold....
We are just trying the little steps up the power ladder.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I've got a ported Scoggin-Dickey base with matching runners and plenum. I've got a Perfect Wiring SD harness and SLP chipped ECM with VATS removed. I'm not baiting you but I need the weekend to determine if I'll sell. I've got an LS deal pending and won't sell if the deal falls through. Will only sell as a package deal. Respond if you think it's something you might want. It was going on my Vortec 5.7.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Can you send or post a picture of the type of manifold? I think I have one that I pulled off a vortec engine but not sure type your looking for.
Guest
Posts: n/a
I have a Vortec combo. I have a set of built ported vortecs. The rocker studs have to be cut down for the camaro. I have all new Manley springs retainers. The base manifold has been mild ported as a port match. Im looking for 1,000 for the vortec combo. There the jbest Gm Vortec out there.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
witch ecm are you needing 1227730 sd 1227165 maf ?
Car: 1988 Pontiac Firebird
Engine: 400 sbc
Transmission: TH400
Axle/Gears: Ford 9" 3.50 35 Spline
I have a SPDC one I might be willing to get ride of it has been on a motor which has been sitting for a while. Email me at smcalees@rocketmail.com if interested.
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
