[WA] 90-92 TPI MEMCAL 5.0/5.7
Old May 20, 2011 | 10:40 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
In need of a speed denstiy memcal for my swap, needs to be either a 305 or 350, V6 would not work for me, i need it to be able to actually limp in limp mode i need this thing ASAP
Preferably the 5.7, the 5.0 will work though
Let me know
Old May 23, 2011 | 01:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 90-92 TPI MEMCAL 5.0/5.7
bump!
Old May 24, 2011 | 11:54 AM
zuuschevy's Avatar
i have several v8 speed density prom. broadcast codes are
axxb 5.0 auto trans
axyb 5.0 manual trans
awfy 5.0 auto trans
or i can burn you a custom one with vats delete and all that other good stuff if your doing a swap.
$100 for the stock proms and $125 for the custom one
Old May 24, 2011 | 12:31 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
axxb 5.0 auto trans
awfy 5.0 auto trans
How about 350 w lt1 cam roller rockers no vats or emissions? If its an eprom that would be great in case I need to adjust anything
Old May 24, 2011 | 12:36 PM
zuuschevy's Avatar
I can get you a prom with a flashable chip with a stock bin file minus all the vats and emissions. But as far as the cam you will have to have it tuned. But at least it will be capable of being reprogramed when go to get it tuned
Old May 24, 2011 | 12:54 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
That works! Ive got a local guy to tune
Old May 24, 2011 | 01:52 PM
zuuschevy's Avatar
We will have to toch base a little later about what you need on it. I can change fan request and things like that too I get you some more specific questions tonight. Sound good?
Old May 24, 2011 | 11:34 PM
zuuschevy's Avatar
Pm sent
Old May 25, 2011 | 07:32 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Are you running a 305 then?
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
