[CA] 1Le A/C delete Pully Wanted
Guest
Posts: n/a
Bracket and pulley will replace the A/C compressor on F bodies with a serpentine belt. This is a factory part on 1LE models which did not bring air conditioning from the factory. Uses the same belt, and the same belt routing as stock. Reuses A/C compressor bolts. Sales 99.00 new Tpiparts.net.. Looking for a good deal..
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1Le A/C delete Pully Wanted
I've got one in real nice shape. Send me a PM ( including your ZIP CODE ) for more details if your interested.
Branden,
You sent me a PM - but I could not reply because your PM's are turned off !!
Here is my reponse to your private message:
Hi Branden,
Here are a few pics of the Delete pulley,
I used the USPS website and The cheapest way to ship would be USPS Priority Mail (insured ) = $14.50
The HP advantage would be minimal - you will not notice it while driving. The bigger advantage would be the wieght savings over the AC system,.... and even that is not super significant.
If your still intrested in the Delete pulley just W/B and let me know. I look for another buyer only if I don't hear back from you by the end of the week. If I do hear back from you I'll send a quick update with all my payment info.
Guest
Posts: n/a
Can you try an pm again, that's weird because Im sending pm's. do the pm's need a check or unchecked?
Receive Private Messages only from Contacts and Moderators, this is unchecked now. I think this was the problem. Because this is where members tell you it says that your pm's are off.
If Pm still doesnt work contact me at CaliBranden@aol.com please. I'll see if I can get payment to you sent by Saturday. If not it would have to be after May 1st for sure. Just depending on ttl cost. Thanks..
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
these can be had at any parts store chain for cheap. i think i paid $28. a/c bypass pulley
Guest
Posts: n/a
Tried sending you another PM.....
CaliBranden has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
If you are trying to send this message to multiple recipients, remove CaliBranden from the recipient list and send the message again.
i have never physically seen an oe 1le delete. maybe the quality is higher? mine came with a plastic pullie. seemed kinda janksey, but has worked well so far....
Guest
Posts: n/a
Ok sorry John, I dont know why there not working because Im sending Pm's and maybe that Moderator and contacts box needs checked.
So just send me an email. So we can get this A/C delete on it's way hopefully.. Because the more I think of the price and what every one has said. Im going is this worth the work and the price..It's not plastic is it? Because Im putting out my most 442rwtq
Just thinking of breaking that.. I could possibly break that style. I dont know hard to tell if your is plastic also in the pic.. I wait on your email...
Just thinking of breaking that.. I could possibly break that style. I dont know hard to tell if your is plastic also in the pic.. I wait on your email... Joined: Aug 1999
You can see the part number in the pic...... This is a factory used part that was sandblasted and re-painted cast aluminum. The pulley is not metal. I no longer have a serpentine motor and have no use for it - at the moment.
Please read:
http://www.summitracing.com/parts/NAL-10055890/
http://www.rmsautoparts.com/proddeta...?prod=10055890
http://www.gmpartsdirect.com/results...umber=10055890
Yes; just like every other auto part you can get "dorman" or other cheaper aftermarket brands thru 'feepay' for a lower price than the GM stuff..........
P.S. Can't say that anymore ! FYI: ANY GM part number 10055890 AC delete pulley - like the one pictured above - is a "1LE" part.
Please read:
P.S.
BikeFarm
Aug 11, 2015 11:35 PM
