[CA] WTB a cam
Old Oct 4, 2012 | 07:18 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
WTB a cam
Lookin to buy a cam that will best fit my current application..
my signature pretty much says it all. lol
thx
Old Oct 4, 2012 | 02:05 PM
88 Z-ROC's Avatar
Re: WTB a cam
something close to the 264hr. 112 lobe
dur. 264 int. 274 exh
dur @ .050 210 / 220
valve .48 / .48
lobe lift .32 / .32
these are comp cam specs
hydro roller
Old Oct 4, 2012 | 02:08 PM
88 Z-ROC's Avatar
Re: WTB a cam
or the firehawk cam
in: .495" 270 218 ex: .502" 276 224
It has 114 LSA
Old Oct 4, 2012 | 09:02 PM
88 Z-ROC's Avatar
Re: WTB a cam
Lingenfelter 219 cam..?
open to any suggestions
Old Oct 5, 2012 | 08:05 AM
88 Z-ROC's Avatar
Re: WTB a cam
Is this cam way off / over kill
233/242 at .050..540/.555 lift with 1.5 rocker. 109 lsa
Old Oct 8, 2012 | 09:01 PM
oramac91's Avatar
Re: WTB a cam
thx
I have a crane cam i have to check the numbers on it.Jason
Old Oct 8, 2012 | 09:39 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: WTB a cam
You are not going to be able to run anything over .480 lift with stock heads without screw in studs.
268ah-8 would be a nice suggestion for that setup. Should really wake it up.
Old Oct 10, 2012 | 08:48 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Re: WTB a cam
https://www.thirdgen.org/forums/engi...8-lifters.html
Old Oct 11, 2012 | 11:10 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: WTB a cam
I have a 230/236 LSA 114 (Comp Cam) ~500 miles on it
And a 219/219 New.
HR cams
Need to look for the cards.
Old Oct 12, 2012 | 08:00 AM
88 Z-ROC's Avatar
Re: WTB a cam
And a 219/219 New.
HR cams
Haven't quite been able to decide just yet.. If you could give me some more info. on both cams it would be greatly appreciated.
Old Oct 12, 2012 | 06:11 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: WTB a cam
The one that is 230/236 ~500 miles on it is:
GRIND#: CS CH 3315S / 3316S HR114.0
--------------------INTAKE EXHAUST
VALVE ADJUSTMENT--HYD HYD
GROSS VALVE LIFT---.544 .555
DURATION @
.006 TAPPET LEFT----281 287
VALVE TIMING OPEN CLOSED
@ .05
INT: 5 BTDC 45 ABDC
EXT: 56 BBDC 0 ATDC
THESE SPECS ARE FOR CAM INSTALLED
@110.0 INTAKE CENTER LINE
DURATION @ .050 230 236
LOBE LIFT .3400 .3470
LOBE SPEARATION 114.0
Other cam 219 never been fired but lubed.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
