Heads/posi rear
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Heads/posi rear
I am looking for some PARTS/upgrades to my GTA. I have an 87 GTA 5.7, with headers, dynomax exhaust, aluminum drive shaft, 3.08 posi rear, stall converter.
I want to upgrade the heads. they are 5.0 heads. I am looking for a posi rear with 3.42 or 3.45.
So, I am interested in buying a set of heads and the rear.
I stated what I have so I can get some advise on which way I can go to upgrade. I would like the car to be streetable and run faster for occasional runs at the track.
Re: Heads/posi rear
Want a title? Post!
Car: 1994 Jeep YJ
Engine: 350 TBI
Axle/Gears: ford 8.8 with 4.10
Re: Heads/posi rear
^ I also have a set of stock 305 Heads sitting on the shelf... but IMO not worth the value to ship.
Re: Heads/posi rear
Thanks for the offer for the heads, but how would be that be an upgrade? lol
Concerning the carrier, do you know what I am using and think it will change my gear ratio? what do you have?
Re: Heads/posi rear
I would have to do some research since I am not familiar with them. But, how much more flow and hp is possible from that head change with a new cam?
Want a title? Post!
Car: 1994 Jeep YJ
Engine: 350 TBI
Re: Heads/posi rear
as for the carrier... you would need to put whatever gears on it that you want when it is being installed. I have no idea what youre running but the carrier is a positraction.
Re: Heads/posi rear
I am looking to add some hp, but would not waste time changing heads to the original equipment, thanks anyway. If I upgrade I want to notice a difference. The stock heads are not gonna do what the aftermarket heads will do. If they were free, I still wouldnt do it. lol And I have decided to look into a swap for the LS1 or 400 LS2, is it? I was told that spending 1500 on heads would do less than the new style LS1 engine. And I can sell the one that I have now. What do you guys think?
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
Re: Heads/posi rear
Yeah that is true but if you wanna stat cheap go steel or alum l98's and do some light port work or go vortex it will make a big difference over Those 305's. theose things don't flow
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
