Wire Loom for Throttle Cable
Old May 8, 2013 | 11:28 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Anyone know a part number or place to find a wire loom for a 1991 5.0 TPI car? It is the one that holds the throttle cables above the intake runners (top drivers side)? It is a 3 position loom that mounts on a post that goes into the intake maifold. The top half broke when I was replacing the fuel injectors and I have not been able to find a replacement. Unfortunately, there are no bone yards with parts cars within 100 miles of me. Thanks.
Old May 8, 2013 | 11:52 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wire Loom for Throttle Cable
That is actually a "spark plug wire" retainer . The OE number is/was 8917256
http://www.ebay.com/itm/NOS-1978-1979-1980-Chevrolet-Monte-Carlo-305-LH-Spark-Plug-Wire-Retainer-8917256-/390571623532?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5aefe2046c&vxp=mtr
Old May 8, 2013 | 08:02 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Thanks for the suggestion but the one you show in the picture is a 4 position spark plug wire loom. It separates plug wires but has no way to anchor to the manifold post. I am looking for a 3 position loom that is used on the throttle cables to keep them routed off of the top of the engine. Appreciate your help but I need to keep looking.
Old May 8, 2013 | 09:34 PM
Engine: Lb9
Transmission: M20
I guess I don't know what you are looking for I thought you were looking for the throttle cable/tv , cruise retainer that goes on the plenum runner stud.
Old May 8, 2013 | 09:49 PM
Engine: Lb9
Transmission: M20
Maybe this will help you find what your looking for.
Old May 9, 2013 | 09:52 AM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Very interesting. Thank you. Now I see where you got the 8917256 part number from - its on this exploded view diag but it is not the one mounted on my block. Here are 2 pics of mine. As you can see, it is a 3 position loom mounted on a shaft that is screwed into the side of the air intake body.
The bolted side on mine is fine, the top clip is the part that is broken. I will keep looking but I really appreciate your help with this. It is a very minor part, but I want to find the exact replacement.
Attached Thumbnails Wire Loom for Throttle Cable-pict0053.jpg   Wire Loom for Throttle Cable-pict0057.jpg
Old May 9, 2013 | 01:12 PM
Engine: Lb9
Transmission: M20
Check with don, he a real good guy and has alot of tpi parts.
https://www.thirdgen.org/forums/engi...9-formula.html
Old May 9, 2013 | 05:47 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Thanks for the contact.
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
