3.1 and 3.4 engine ?
Old May 11, 2013 | 08:17 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
If I have a 3.1Liter engine and am going to swap a 3.4Liter engine?
What are the only parts I need to take from a 3.4 engine?
I'm thinking sorry if this is a dumb question? I have
Little knowledge on cars.
Block ? Heads ? Fuel injectors ? I'm buying a new water pump.
What else ?
Old May 13, 2013 | 11:39 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: 3.1 and 3.4 engine ?
If you ask the Moderator to move this to the V6 section, you'll have great luck getting this question answered.
Old May 14, 2013 | 05:47 PM
ultraz's Avatar
Car: 02 UltraZ, 85 Z28, 98 WS6, 86 Vette
Engine: LS1, SBC 383, LS6, LS2, LQ9
Transmission: T-56, TH400, 4L60E,
Axle/Gears: 3.42s, 3.73s, 4.10s
why not just drop a L67 in???
Old May 16, 2013 | 01:05 AM
KG427KG427's Avatar
Car: 1991 camaro
Smog reasons. I live in Cali. Better off 3.4 build
Old May 16, 2013 | 10:10 AM
ultraz's Avatar
as long as there's no lights, hell, you can drop a v8 in too.... you just need to make sure all the emission junk is set up right... 350s are getting cheap now everyone wants a LSX swap... or even lt1... unless you just want to stick with a v6... 3.8 or 4.3, there's no reason why a newer gen motor shouldn't run cleaner than a early 90s v6 unless you cam and tune it
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
92projectcamaro
Aug 6, 2015 01:20 PM
