[NJ] 350 engine
Old Jun 17, 2013 | 12:26 PM
deity4uu's Avatar
350 engine
Looking for a 350 engine to swap into my 91 z28 convertible. Please call me at 718-316-1993 or e-mail me at saladinjose70@yahoo.com.
Thank you.
Old Jun 17, 2013 | 12:45 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Re: 350 engine
I have a 1989 GTA Parts Car with a 350 on it...
Old Jun 17, 2013 | 12:46 PM
deity4uu's Avatar
Re: 350 engine
Where is the engine?
Old Jun 18, 2013 | 01:46 PM
Pontiac_Pete's Avatar
Car: '97 TA WS6 vert & '88 Formula 350
Engine: LT1 & 383 HSR
Transmission: T-56 & T-56
Axle/Gears: 3.42 & 3.27
Re: 350 engine
Where are you located? Do you want a runner or a core?
Old Jun 18, 2013 | 01:48 PM
deity4uu's Avatar
Re: 350 engine
I am in northern NJ. I want a 350 to rebuild and then swap into my car.
Old Jun 18, 2013 | 02:21 PM
Re: 350 engine
I have 2 engines. one is still in the car, it has no compression in cylinders 2 & 4. 8 think it is in the head, but need to do a leak down test to be sure. It came out of a '89 Formula 350. I also have a bare 4 bolt main block that is ready for machining. It had 2 spun main bearings but the scoring is not bad, it came out of a '97 GMC 2500.
Old Jun 18, 2013 | 05:27 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Re: 350 engine
I have a short block for sale and I am in Northern NJ
Short block is from a 1992 Z-28 5.7 L-98.
Camshaft type (P/N 12370846): Hydraulic roller
Camshaft lift (in):.509 intake / .528 exhaust
Camshaft duration (@.050 in):222'c1 intake / 230'c1 exhaust
Stock oil pan.
Old Jun 19, 2013 | 08:18 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Re: 350 engine
i have a 350 roller block out of a 91 camaro. will need to be cleaned up at machine shop as it is rusty due to being stored outside. engine complete from manifold to oil pan. also, i am located in north Jersey. $200 and it's yours. not looking to make money just need it out.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
