[WA] wtb set of (8) 89 5.0 TPI Injectors
Old Sep 1, 2013 | 03:16 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Hey all, looking for a good set of 8 stock 5.0 TPI Injectors for my 89 Formula. These would be the Multec ones w/16.0+ ohms. Not sure of the original part number but think the rated flow is 19 lbs/hr. As I recall the 89-92 5.0 TPIs used the same injectors. Can pay w Pay Pal...
Old Sep 1, 2013 | 04:37 PM
iroczlbc's Avatar
Want a title? Post!
Car: IROC Z
Engine: 5.0
Re: wtb set of (8) 89 5.0 TPI Injectors
I have a set of 19 lb injectors off a 89 Camaro 5.0 if your interested
Old Sep 1, 2013 | 05:40 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
PM reply sent.
Old Sep 2, 2013 | 09:41 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Still lookin'! Anyone??
Old Sep 3, 2013 | 12:50 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
$65 Shipped,.......... ( Need to be painted ! )
$80 Shipped,.......... ( Should be painted ! )
Both sets are 305ci, 19lb injectors. I had them hooked to a switch and heard each one "click" as I pushed the button and released. They were also OHM tested before I cleaned them up. I don't install used injectors myself without installing new filters and O-rings....... I recomend it with these too. Flow testing not a bad idea either.
Send me a PM if your seriously interested.
Old Sep 3, 2013 | 06:45 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I have these that I bought new a few years ago from WS6project. 82-02 V8 Ford Racing SVO Fuel Injectors (19lbs/hr)
I swapped motors 2 years ago so they have not been used that long. Probably only a couple hundred miles on them. They are like new
Old Sep 8, 2013 | 05:31 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
John in RI and Pop6482 - thanks for the replys and offers, but I'm looking for the GM/AC Delco Multec Style injectors. Those Bosch style ones might work fine but I feel better about getting the right ones like came original on the engine. I've got to get the old Bird through WA emissions one last time before it's a "Classic" and no longer subjected to regular testing...
Old Sep 8, 2013 | 05:33 PM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
iroclbz - if you still have those injectors and TPI stuff I'm still interested - haven't heard back from PMs sent to you so trying a reply here...
Otherwise folks, still looking for some GM/AC Delco Multec Injectors for my 5.0/305 89 Formula...
Old Sep 11, 2013 | 12:29 AM
streak_06's Avatar
Want a title? Post!
I have a factory set from an 87 iroc if interested.
colton_carlson
Mar 8, 2019 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
Firechicken86
Aug 12, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
