Hydraulic roller cam, Vortec carb Intake, sbc flat top pistons, Ignition
Old Jan 20, 2014 | 09:30 PM
Jose Zuñiga's Avatar
Hi,
I'm looking for a good hyd roller cam (lift can be 0.500 to 0.510), vortec intake for carb, flat top pistons std and a good ignition system.
Old Jan 22, 2014 | 04:54 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: Hydraulic roller cam, Vortec carb Intake, sbc flat top pistons, Ignition
i have the vortec intake for a carb set up
Old Jan 22, 2014 | 06:27 AM
Please send me the part number
Old Jan 22, 2014 | 03:24 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
What ignition parts are you looking for. I have a billet distributor, msd coil and 6al box.
Old Jan 22, 2014 | 06:58 PM
Distributor, CDI and a Coil.
How much for those parts?
And what brand is the distributor?
Old Jan 22, 2014 | 07:06 PM
Distributor is an off brand but is a MSD clone. CDI and coil are MSD. $300 for all
Old Jan 23, 2014 | 05:37 PM
Transmission: auto
Jose Zuñiga, i dont have a part number, but i can give you a pic
Old Jan 29, 2014 | 12:14 PM
Thank both for reply.
Thanks but I want a branded distributor. How much for the CDI?
Do you have the specifications of the intake? Thanks
Old Jan 29, 2014 | 12:52 PM
6AL and coil $200
Old Feb 11, 2014 | 07:57 PM
87oldschool's Avatar
I have a killer Lunati hydraulic roller cam, Melling Hydraulic roller lifters(soaking in oil,sealed) Melling pushrods and Magnum roller tip rockers 16-1:52 factory ratio and 8-1:6 ratio for exhaust side gives added lift let me know if you are interestedd I will make you a deal on all! If interested I have the cam card I can send you direct from Lunati.
Thanks,
87OldSchool
Old Feb 16, 2014 | 09:55 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
pm sent
Old Feb 16, 2014 | 11:56 AM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
i have flat top pistons that will give you 10.2 compression W/ 64 cc head and .040 thick HG. they have roughly 8k miles on them
Old Feb 18, 2014 | 02:12 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Have Pink Rods with Mahle hyper-eutectic pistons no scoring or issues. $100 for rods and pistons; just need cleaned.
Old Feb 19, 2014 | 06:10 PM
dpmalibu's Avatar
I have a Pertronix distributor, coil and ignition box for sale
Old Feb 24, 2014 | 11:27 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Are you putting the roller cam in a roller block? The only reason I'm asking is I have a complete retro-fit roller lift cam kit with Comp retro-fit cam for NON-ROLLER blocks, Comp retro-fit rollers, the correct pushrods and timing set. None of this fits a roller block.
Old Mar 1, 2014 | 10:52 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
I have a zz383 roller cam and vortec intake...let me know if your interested
Old Apr 5, 2015 | 07:39 PM
doppler's Avatar
Comp Cams $275 new - This cam has very few miles on it. I want $150 for it.
Tim 918-527-5316
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,900-5,600
Intake Duration at 050 inch Lift: 227
Exhaust Duration at 050 inch Lift: 241
Duration at 050 inch Lift: 227 int./241 exh.
Advertised Intake Duration: 283
Advertised Exhaust Duration: 303
Advertised Duration: 283 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.498 in.
Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.498 exh.
Lobe Separation (degrees): 107
Camshaft Gear Attachment: 3-bolt
Computer-Controlled Compatible: No
Grind Number: 283THR7
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
