[NC] T5 swap
Old Sep 21, 2014 | 08:50 PM
jovibuilt's Avatar
T5 swap
Looking for everything to swap a t5 into my 85 Trans Am.Must be a v8 t5 thanks
Old Oct 5, 2014 | 10:02 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: T5 swap
Would you be interested in a clutch disc,flywheel and slave cylinder?
Old Oct 6, 2014 | 07:42 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: T5 swap
I have a complete WC T5 swap I just pulled, but shipping would be required due to the distance between us.
Old Oct 22, 2020 | 12:48 PM
Gordon G E's Avatar
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Re: T5 swap
I also did this swap with the 600. Right gear ratio's & all. I used Abacba's swap as a guide. I got a bell housing from Southwest speed for $200 and a hydraulic clutch slave instead of the stock type. Also did the UMI mount and torque arm kit, as the TKO doesn't have the provision to mount the stock arm. Also the shifter extension to place the stick closer to the stock location. BTW, the TKO bolt paaren is the same as the T5, but the stock bell housing is tipped 18 degrees to the left. The trans mount is crooked ans there an adapter would need to be made. Not a real hard swap. And it shifts great. I am quite pleased with the trans.
Old Oct 22, 2020 | 02:53 PM
prossi's Avatar
Re: T5 swap
i have a bellhousing
Old Nov 13, 2020 | 12:05 AM
Stephen Thomas's Avatar
Car: 84 Trans Am
Engine: 5.7 zz430
Re: T5 swap
I have a WC T5 that was rebuilt about 5 years ago.
Old Dec 17, 2020 | 02:53 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: T5 swap
I have a complete setup flywheel, clutch, shifter, trans, pedals, etc. Pulled from my 88 firebird. I'm in northeast mississippi if that's not too far we can work out a price.
rdicarlo
Feb 15, 2014 09:09 AM
Camman9167
Mar 22, 2012 12:23 AM
Jproz1167
Mar 31, 2003 12:46 PM
wingnut
Jun 8, 2002 02:36 PM
