[MN] Wanted: Rubber Shifter Boot T5 1984 Z28
Old Jul 26, 2015 | 06:46 AM
Saxondale's Avatar
Car: 84 Z
Wanted: Rubber shifter boot that bolts to the floorpan. For 1984 Z28 5 speed.
I am installing a Pro 5.0 shifter and do not want to cut original boot, in case ever want to return to stock shifter.
So even one that is cut for Pro 5.0 would work, provided it is cut well and not hacked.
Must be clean, good condition, and not cracked, dry rotted, torn.
Thanks,
Rich
Twin Cities, MN
Old Aug 15, 2015 | 02:14 PM
ILLIROC89's Avatar
Car: 89 Iroc 78 z-28
Engine: 350 tpi
Axle/Gears: 2.77:1
Re: Wanted: Rubber Shifter Boot T5 1984 Z28
Did you ever find the shifter boot?
Old Aug 15, 2015 | 02:32 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
These are available new from Hawks.
Used ones are kinda a wast of time considering they are very fragile with age.
http://www.hawksthirdgenparts.com/bo...-reproduction/
Old Aug 15, 2015 | 04:50 PM
Saxondale's Avatar
Car: 84 Z
I did not find a boot, but also learned during the Pro 5.0 installation that the original boot did not need to be cut. The Pro 5.0 instructions in the box apparently are for mustangs.
Nice to know the new ones are available. The steel ring on mine has some corrosion. I'll replace it should I repeat the misery of removing that console.
Thank you for the help.
PurelyPMD
May 5, 2016 04:57 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
david068513
Sep 18, 2015 10:36 AM
Exxon Limited
Aug 9, 2015 08:13 PM
