[OH] WTB TPI Fuel Rail Connector
Car: 2002 Camaro SS
Engine: Built LS
I'm looking for the connection piece that attaches to the fuel rail and runs under the alternator and then connects to the 2 flexible fuel lines.
I have attached a picture of what I need.
Car: 89 Iroc Convertible
Re: WTB TPI Fuel Rail Connector
You need the 2 metal lines that attach to the rubber hoses?
Car: 2002 Camaro SS
Engine: Built LS
Correct it connects to the front of the fuel rail and runs under the alternator and connects to the rubber hoses.
I attached the picture to show the front connection.
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
I've got the metal lines $25 shipped. Best pic I have on hand
Car: 2002 Camaro SS
Engine: Built LS
I guess they used the same setup on the older belt setup then? I wasn't sure of that.
They are are in solid shape and not bent on removal correct?
Engine: 305, 355
Pretty sure they're the same between years. I need to pull them off the motor but they are clean and not rusty. Going to be a day or two thanks to the snow
There are 2 different versions.Which one do you need?
Car: 2002 Camaro SS
Engine: Built LS
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
- Eric-86sc has/shows the 85-87 multi-v-belt lines. These run away from the engine, around the AC brackets, and are pretty long and bulky to box up.
- I don't recognize the 2 styles from my82roc.
- This ebay auction has the 88-92 serpentine version of fuel lines, which are fairly short, and compact to box up. These run behind/below the alternator. At least for a Camaro... don't know if Firebird are different.
http://www.ebay.com/itm/88-92-Camaro...VVrtO7&vxp=mtr
Car: 2002 Camaro SS
Engine: Built LS
I attached a few pics I took of what I have but the eBay ad you linked looks the same. I don't seem them being any different.
Im not sure what years mine are from but I only pull these off of TPI cars.
Engine: 305, 355
Looks like you have a set that I also have. On an 88 formula, would have to pull them to see if they twist
Car: 2002 Camaro SS
Engine: Built LS
Well if anyone has a set that is listed like the Ebay ad and got them off without twisting let me know what you want shipped to 45242.
I think any from 88-92 will be the same when they switch to the serpentine setup.
Engine: 4++,350 & 305 CIs
85-87 and 88-92 are the cutoff yrs for both the Camaro and birds.
Car: 2002 Camaro SS
Engine: Built LS
Car: 2002 Camaro SS
Engine: Built LS
Car: 2002 Camaro SS
Engine: Built LS
OK boys here is the piece I need. Let me know if anyone has one in good shape and what the shipping is to 45242.
Car: 2002 Camaro SS
Engine: Built LS
Anyone have what I just posted above? I rather buy from one of you guys then go to Ebay etc.
I have another set buried in my shed.If I can get to them I'll see if they match yours
Car: 2002 Camaro SS
Engine: Built LS
If you do we could just do one box for the battery cable and these.
Let me know
Let me know
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
You can contact Tealman92 on here...I believe that he has this part if you still need it.
Car: 2002 Camaro SS
Engine: Built LS
Hawke I bought off ebay a while ago, no one had the one I needed ready to go.
Since you are close to me let me know if you any anything else interesting for sale.
Johnny*G
Jan 29, 2016 01:23 AM
'91CamaroRS
Jan 24, 2016 10:39 AM
