Oil cooler needed
Old May 3, 2018 | 04:42 PM
Thirdvert89's Avatar
Oil cooler needed
In need of the oil cooler adapter it is part that oil filter screws into I'm in Las Vegas need asap
Old May 3, 2018 | 10:47 PM
Drew's Avatar
Re: Oil cooler needed
Why? If you unscrew the center tube, the sandwich heat exchanger comes off, then you'll have two studs sticking down that hold the oil filter adapter like you'd have on any GM V8 without an oil cooler. Pull the two studs and replace them with regular bolts, and it's just like the cooler was never there.
Normally I'm not one to 'delete' things, but if you're just trying to get a basket case going....
Old May 5, 2018 | 10:17 PM
NoEmissions84TA's Avatar
No details on your car - maybe this will help?
https://www.jegs.com/p/Trans-Dapt/Tr...80459/10002/-1
Old May 5, 2018 | 10:20 PM
87 trans am 305 tpi
Old May 6, 2018 | 11:27 PM
This?
or this?
Here is the complete thermostatic oil cooler adapter assembly from Jegs.
p/n Derale 25720
Old May 15, 2018 | 07:38 AM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
yea my oil cooler only had the center tube that threaded onto the reguler adapter, its not boled like the other cars with the two bolts .
Old May 16, 2018 | 01:18 AM
No that picture is not the one in my car but I had a guy weld a cover over the hole and then job weld it it stopped leaking seems like it's worked
geehumshriber
Jul 9, 2007 09:00 PM
88305tpiT/A
Dec 22, 2002 09:31 PM
86BIRD-MY FIRST CAR
Dec 14, 2001 03:21 PM
