What is the rpo for an engine oil cooler.and where is the cooler located
Old Apr 19, 2001 | 11:19 PM
Stormshadow GTA's Avatar
thanks
Old Apr 19, 2001 | 11:34 PM
BenDoe's Avatar
I can't tell you the RPO code right now, but there are water lines that come from your radiator and go the the top of the oil filter, then back to the radiator.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Apr 20, 2001 | 01:31 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
KC4, and the oil filter screws into it.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 20, 2001 | 08:43 PM
irocrob's Avatar
Car: 1985 Chevrolet Camaro IROC
The RPO is KC4. It is only gound on 87 to 90 IROC's and 91 to 92 Z-28's. It consists of two coolant lines that run to and from your oil filter base.
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
Old Apr 21, 2001 | 12:04 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by irocrob:
It is only found on 87 to 90 IROC's and 91 to 92 Z-28's.
</font>
Also on the Pontiacs (GTAs/Formulas) .......hey man, don't forget about us ..........
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old Apr 21, 2001 | 12:05 AM
Matt87GTA's Avatar
</font>
Matt
Old Apr 21, 2001 | 04:17 AM
FlashGTA
Guest
Posts: n/a
If you don't have one already don't put one on. Get an aftermarket oil cooler that is an air cooled unit.
Old Apr 23, 2001 | 07:52 PM
will i have one on my 87 305 GTA
Old Apr 26, 2001 | 04:43 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
the oil coolers are a rare option, generally packaged with the G92 package (on the Camaros at least)... they aren't really that good of a setup, but if you can get a stock oil cooler and run the lines into an aftermarket cooler.....
Webmaster: www.IROC-Z.org
Old Apr 26, 2001 | 06:24 PM
90Form350's Avatar
Yeah, i have it on my formula. the only thing i noticed so far that it does is make more spots to leak coolant, and makes it harder to pull your motor : ).
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
