[TX] WTB Superram Throttle Bracket
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I am looking for Accel cable bracket for Superram somebody has one lying around
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
Re: WTB Superram Throttle Bracket
Were going to have to figure out something else. I don't think anyone wants to sell their brackets. I been looking for 5 years.
Engine: 4++,350 & 305 CIs
If you are handy, you can make one from a TPI bracket, unless you are going for a "correct" look.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 90 Formula 350
Engine: Lb9
Transmission: M20
The holes look like there close to the bend.
the sr bracket has a brownish coating on it.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'll take it off your hands if you wind up not using it and will pay what you've got in it>
Car: 90 Formula 350
not unless black is weird
yeah on the holes, the "angle" on this is same as stock not 120 degrees as measured on a SR bracket
I also have one of those oddball "SuperRam" brackets sitting around, stumbled upon it a year or so ago. It was labeled the correct Accel part # too. No idea what it really goes with?
Engine: Lb9
Transmission: M20
That’s odd, I think the tpi bracket has tp1 or tp2 stamped on it.
Car: 90 Formula 350
tpi88camaro
Sep 27, 2018 07:58 AM
84redta
Apr 23, 2010 03:37 PM
Bullydawg
May 4, 2009 05:52 PM
