WTB V8 T5 CLUTCH FORK PIVOT BALL STUD AND PRESSURE PLATE BOLTS
Old Apr 26, 2023 | 08:29 PM
STEALTHWRAITH's Avatar
Doing a t5 swap need a oem pivot ball stud and six pressure plate bolts that hold the clutch to the flywheel
Old Apr 27, 2023 | 01:53 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: WTB V8 T5 CLUTCH FORK PIVOT BALL AND PRESSURE PLATE BOLTS STUD
I found a new fork pivot stud online,... Pretty sure it was @ RockAuto.
Old Apr 27, 2023 | 02:17 PM
out of stock
https://www.rockauto.com/en/parts/at...ivot+ball,2010
Old Apr 27, 2023 | 04:04 PM
Scott's 83' Z's Avatar
Car: 1983 Z28
Engine: L69
If this the "Z" bar pivot bolt you are referring to... Rick's Camaro's part# 33-261513-1. $17.99
Worked for my 83 w/manual linkage.
Old Apr 27, 2023 | 04:28 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
You can order the bolts from ARP, just make sure you get the right ones (one piece rear main seal vs two piece)
Old Apr 27, 2023 | 06:19 PM
John in RI's Avatar
Summit Racing = $11 & "in stock" ! ( hydraulic clutch)
https://www.summitracing.com/parts/h...maro/year/1992
Old Apr 27, 2023 | 10:52 PM
The pivot ball needs to be 1.75 in length those are for 1983 and earlier 1.5
Old Apr 27, 2023 | 10:54 PM
Would you happen to know the length and size for the pressure plate to flywheel bolts not the flywheel to crank bolts
Old Apr 28, 2023 | 05:58 AM
Car: 1983 Z28
you can do a search on here to verify but these should be it:
https://www.summitracing.com/parts/a...oK2kV65nMlPySM
Dante93GTZ
Sep 13, 2010 07:02 PM
timfoxrs
May 12, 2006 06:27 AM
