would i be safe with a junkyard 350?? no rebuild
Old Apr 23, 2002 | 08:28 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
hey..i'm getting a bad knock....ticking .. noises....no oil pressure.. etc... the 305.. is on its way out..
i have less than 500 bucks..
do you think it would be safe....to just get a 350 from the yard.... throw it in and go?.....
what year 350 would i look for?
i can get one for 200 bucks.....
i have 500 bucks to my name.. and a motor that wont run.....
Old Apr 23, 2002 | 08:43 PM
Guest
Guest
Posts: n/a
I thought you had 50 bucks?
Old Apr 23, 2002 | 09:30 PM
Car: 1983 Z28 Clone
Transmission: TH350
hahahha....
yeah.. in my pocket...
i can cash advance my credit card....
for EMERGENCIES...but.. its the last resort..
Old Apr 23, 2002 | 11:45 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
might be worth seeing what reconditioned engine are going for IF you can get a warranty of some sort with one.
https://www.thirdgen.org/techbb2/sho...hreadid=100768
Old Apr 24, 2002 | 04:25 PM
Car: 1983 Z28 Clone
Transmission: TH350
i was thinking of going to autozone.. or pep boys.. but it seems like everyone is against it.... i mean.. i think they even have a payment plan..wich would be good for me.............but............i dont want it to blow up.............
but...........it would be better than an engine from the junkyard....
rob
Old Apr 24, 2002 | 05:15 PM
Check with your local GM Dealer, GM Parts Direct, a Brand New 350 TBI Caprice engine, is about $1,800 with a 3 year 50,000 mile warranty. I know this is more than you want to pay, but you could get a Credit card application with zero percent intrest for a few months and use that to swing getting the car fixed. Would be worth the piece of mind in the long run.
Or ask around someone may have a still running 305 they will give you a killer deal on for like $100 or so. Running 305's go for about $200 at a local junkyard and they will install for $350 to $500 depending.
Good Luck
Old Apr 24, 2002 | 07:05 PM
Joshua Leslie's Avatar
junk yard motors are ok, just be sure to hear it run first, the yard I have goten engines from let you go to the yard, pick which one you want, then they pull it out of the car for you, but let you hear it run first. this may not always be possible of course.
At the very least, they will proly give you a 30 day warranty or something like that, they usually do for engines and trannys.
Old Apr 24, 2002 | 08:34 PM
Car: 1983 Z28 Clone
Transmission: TH350
actually i found a place ..today that sold engines for 99 bucks
35 dollars to pull...
thats 134.................bucks...
but they drain all of the oil and fluids...........before entering the yard....
and most of them are stripped..........
ill look into it...
i'm just trying to get things straight..BEFORE this engine goes.....
and i've never done a transplant.. but ..friends say its easy...
Rob
Old Apr 27, 2002 | 05:08 PM
70Monte355's Avatar
Pick up a local trader mags. I don't know about Buffalo, but around here there are lots of motors in their and quite a few of them have not been pulled yet and you can hear them run.
Give it a try..your best bet is to do that.
I know your short on money, but I would go ahead and replace all the gaskets and the timing chain. It is a lot easier to do that stuff while it is out of the car anyway and then you don't have to worry about it for a long time to come.
Old Apr 27, 2002 | 09:21 PM
cdogc350's Avatar
Look for a 350 with the last three #'s on the serial # being "010" when i was an apprentice mechanic a while ago, my boss told me these where alot tougher.......thicker walls, 4-bolt mains, supposed to be the best for a hi. perf. build up
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
fbirdroller
Sep 2, 2015 10:27 PM
Eric-86sc
Aug 24, 2015 09:01 PM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
