383 question
Old May 1, 2002 | 07:45 PM
383 rocket bird's Avatar
383 question
I have built a vortec headed 383 and I was just wondering if I will be able to get it started and running on the stock chip without any damage to the engine from an over lean condition or anything else. I just want to get it broken in on the stock chip and then I plan to buy the supplies to start burning my own chips. Thanks -John
Old May 2, 2002 | 12:55 AM
Come on guys I've searched the boards and can't find a clear cut answer to this question. I know optimal performance means new chip but am I gonna hurt anything by just staring it up on this chip?
Old May 2, 2002 | 01:30 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
I doubt it...
WELL.. I wouldn't start it on the stock chip, my quess is that is it would be WAY to lean, which of course is what you don't want...
other know more about this than me so TTT...
By the way My 388 vortec KICKS ***! (carbed, and "worked" a bit)
Old May 10, 2002 | 12:09 PM
primo's Avatar
BumpaD82 ,
Are this the original valve covers?
What kind of heads are they?
It looks super
Old May 10, 2002 | 01:42 PM
Guest
Guest
Posts: n/a
Easy now...
Need more input. What cam? What ECM?
Chances are, it'll be fine. Reprogrammed chips are generally for optimization of the available power, not prevention of sure meltdown.
Old May 15, 2002 | 12:09 AM
I am building a 383, vortec heads, GM LT4 HOT cam, SDPC intake, stock runners, plenum, tb, edelbrock headers, and stock exhaust. I do not have an AFPR. I was just wondering if I could start and run the car on the stock chip without hurting anything. I want to get it broken in this way and get the bugs worked out then start burning my own chips and making more mods. I am really nervous about this and could really use some help. Thanks guys
Old May 15, 2002 | 12:10 AM
I have the stock 89 350 TPI ecm
Old May 15, 2002 | 12:41 AM
Guest
Guest
Posts: n/a
I dont see any problem in you running that car. The larger engine will help mask the cam, and that will make the computer more happy. I'm running a slightly larger cam in a 350 that was on the stock chip for a while until I decided that I needed something better in there.
If it trips a code 33, set the TPS lower (like .35v) and it shouldnt be a problem anymore.
Old May 15, 2002 | 01:27 AM
BumpaD82's Avatar
Originally posted by primo
BumpaD82 ,
It looks super
NO the valve covers are off an 88-up truck repainted, and the heads are GM performance parts Vortec's, upgraded with comp cams brand valvetain 268 XE "kit", and machined for higher lift / springs....
Old May 15, 2002 | 11:54 AM
WesTek's Avatar
John (383 RB), I'm planning a 383 similar to yours, how much $$$ have you put into your engine (parts and machine work)? I need a rough estimate on how much to get started.
wes
Old May 15, 2002 | 12:38 PM
Momar's Avatar
I imagine it would be fine for break in at least. It is mass air flow so it will compensate at least to the ability of the maf sensor. It might be possible that you would lean out in the upper rpms, but like I said I would think it would be fine for break in.
Ben
Old May 15, 2002 | 04:10 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I ran on the stock chip for along time, like a year, with no problems.
Old May 15, 2002 | 04:32 PM
Momar's Avatar
Hey, madmax, I just noticed your location. Has it always been anti-tbi school, or is that just because of those people arguing about making power from a tbi?
Ben
Old May 15, 2002 | 10:33 PM
I've probably got about 3,500 into it right now and all the odds and ends will be calculated because I am hoping to drop it in tomorrow. Good luck with your build up
Old May 16, 2002 | 10:14 AM
Guest
Guest
Posts: n/a
Ben
Actually I was called the Anti-Christ of TBI.
But yea, thats when it changed.
Old May 16, 2002 | 10:48 AM
Momar's Avatar
Well, I think you can get power out of any kind of induction if you have the money/time(forced induction helps also lol) but some are just a more worthwhile starting point than others.
Old May 16, 2002 | 01:35 PM
BadBird84's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.8l :(
Transmission: T-5 Five Speed
If you run tha stock 350 chip it's gonna be waaaay lean, youc an buy a programmer though, they aren't too hard to use : :lala: :rockon: :rockon: :lala: :lala: :lala: :lala:
Old May 16, 2002 | 01:50 PM
Momar's Avatar
He said he is planning on getting a programmer eventually. It is mass air flow so it will not be lean until he max's out the mass air flow sensor. I seriously doubt that he will max it out at part throttle breaking it in. If he max's it out then programming it wont be as easy either though because he will have to add fuel by rpms I believe instead of by how much air is entering the engine.
Ben
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
