anyone have specs on a stock chevy 400?
what are the specs on these motors stock? im going to be buying a 400 small block off of a freinds grandfather, its been in his garage and needs to be rebuilt. but the thing is.. i wouldnt have too much money to do it... so if i rebuild it to some stock specs and upgraded later, what kinda power would i be looking at?
Transmission: 4L80E/4L80E
The '70 Impala 400 2bbl I had was rated at 265 HP. That's a gross flywheel rating, not the net we're using now.
Compression was on the order of 9:1. Heads were terrible for performance. Cam was intended for smooth idle and low rpm torque. I put a q-jet and dual exhaust on mine, hardly made any difference.
The shortblock is a great foundation for a performance engine. Everything else is boat anchor material - cam, heads, intake, exhaust, etc.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
GM never used a 400 small block in any Camaro. Starting in 1970 Chevy used a 402 big block in the Camaro, however it was badged 396.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
More commonly, 400's were used in station wagons, pickup trucks and vans. The trucks stopped getting them in 1979. They were never put into any sort of performance car since they weren't built for performance. No 400's came with 4BBL. They were all 2BBL
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Pete
Car: 87 IROC L98
I was too lazy to correct it. Look at the next message. 400's in trucks had q-jets but are still not performance engines.
Car: Camaro
Engine: 355c.i.
Transmission: th350
theyre referring to the chevy 400...not a pontiac 400... the pontiac 400 is "big block" pontiac
400 chevy is a bored out/stroked whatever small block 350 i believe
The small Chevy 400 is a siamesed-cast cylinder, 4.125" bore, 3.75" stroke, increased journal size, shorter rod, externally balanced version of the SBC. It shares external dimensions and bolt patterns with the 350 (and the smaller versions, of course), little else.
Cams will fit, lifters/pushrods/rockers are the same, intakes will bolt on - that sort of thing. But, there are a lot of little details that are different.
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
they are also hard to come by these days. I was able to find two of them for 50 bucks a piece. and always looking for more.
they are not bad blocks, but in stock form they suck. but being able to get big block power out of small block size.
but i do like the big main journals, that can handle a lot of stress.
ambainb
Apr 25, 2016 09:21 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
