L03 Removal ?
Old Jun 11, 2002 | 06:22 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
L03 Removal ?
Pulling L03 out of a 91 with 5-speed and installing a ZZ4 [TPI] with six speed. Should I leave the wiring harness and pull the engine or pull the harness with engine?
GTAFOX
Old Jun 11, 2002 | 11:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Doesn't much matter, since you won't be reusing the harness.
But, the less hanging off the engine when pulled, generally the better.
Old Jun 14, 2002 | 10:32 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
yup
When I pulled my L03 I disconnected everything and left the harness in until after the engine was out. I also removed the T-5 before the engine, seemed alot easier.
Old Jun 15, 2002 | 05:23 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
Thanks for the info. guys. The wiring harness replacement is going to be a bitch to replace. Thanks again.
GTAFOX
Old Jun 15, 2002 | 08:40 AM
five7kid's Avatar
The harness isn't as bad as you might think. Once everything is disconnected from the engine (which is most of it), leave the sensors attached to the harness, unbolt them from their mounting, and remove it all as one piece.
What are you doing for a TPI harness? If from a donor car, do the same thing - leave the sensors attached to the harness, unbolt, remove. It helps to label everything as it is disconnected/unbolted, as to location and/or to what it is attached.
Old Jun 15, 2002 | 10:59 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
L03 Removal
Thanks for the info. The TPI harness I have to replace the L03 harness for 91 SD. I marked all sensers on that harness. The problem that I am going to have is at the other end. The right side passes behind the the engine going to the left side and the left side passes behind the engine going to the right side all in one roll!!Plus the power wiring. Any advice on the hummer?
Thanks again!!!
GTAFOX
Old Jun 15, 2002 | 12:34 PM
five7kid's Avatar
It's been almost 3 years since I did mine, and I have a carb. But, as I remember it, when everything was disconnected/unbolted, the whole thing went over the passenger side fender. Disconnecting the pass-through at the passenger side kick panel allowed the whole thing to come free from the car (take the plastic fender liner out to get access to it). The big connector package on the driver's side firewall can be seperated.
From what I've heard from others with TBI/TPI cars, they are basically the same as what I observed.
Old Jun 15, 2002 | 01:15 PM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
L03 Removal
Five7kid thanks again! I have the fenders
off so that will make it alittle easer. Is the power wiring mixed in with the computer wiring?It looks to me like thier are 2 right side harness and one left side harness??Does all the harnesses go to the computer?I have a 91 B4C as a model but I am still confused!!
Thanks again
GTAFOX
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
