ZZ4 Distributor Gear on OEM HEI!???
Old Jun 13, 2002 | 08:52 PM
SpikeIROC's Avatar
Hey 'sup guys.
I've bought a ZZ4 camshaft to put in my new 350. My previous engine was an all mighty 305 TBI from a 89 Camaro.
The 305 was using a HEI 2 connectors type distributor. I red somewhere that if I wanted to use that distributor with my new ZZ4 camshaft, I'd have to change the gear on the distributor. So that's what I did, and bought a 10456413 melonized gear... and it's loose on my distributor shaft. There's a lash of about 1/16...
How come? So I need to change my distributor? What if I run the engine with my old gear?? What's the difference between 'em (exept what they are made from).
Any help would be GREATLY appreciated.
Thanks a lot.
Old Jun 13, 2002 | 09:58 PM
Guest
Guest
Posts: n/a
Sounds like you got the wrong gear, there are 2 different shaft sizes GM used. The factory gear is supposed to be melonized anyway, just use it.
Old Jun 14, 2002 | 08:44 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You know I've got a ton on the shelf, but never looked at 'em side by side. I'm told they are different, and it will chew up the cam..
Old Jun 15, 2002 | 12:33 AM
Morley's Avatar
One is Bronze alloy (for roller cams) the other is steel (for flat tappet cams)
~M~
Old Jun 15, 2002 | 12:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you are re-using the distributor from the '89 LO3 TBI, you do not need a different gear for the ZZ4 cam. Both are factory roller types, and like madmax said, they use melonized gears on factory roller engines.
You don't want to use a bronze gear on a factory roller cam.
Old Jun 16, 2002 | 10:46 AM
SpikeIROC's Avatar
Thanks a lot guys... I will follow your recommandations!!
Old Jun 17, 2002 | 08:39 AM
ATOMonkey's Avatar
I wanna jump in on this. I know that you need a special gear to run roller cams, but what if you going the other way putting a ZZ4 dist. onto a flat tappet cam?
Old Jun 25, 2002 | 08:39 AM
five7kid's Avatar
No problem. The melonized gear will work on either type.
Old Jun 25, 2002 | 01:38 PM
ATOMonkey's Avatar
Thanks.
Old Jun 28, 2002 | 01:13 PM
Damon's Avatar
GM factory roller cams don't require a bronze gear like most aftermarket roller cams do. They somehow integrate a hardened gear onto their roller cams that is basically the same as on their flat tappet cams.
lt500r55
Sep 1, 2021 01:30 PM
jklein337
Sep 19, 2018 06:23 PM
fbirdroller
Sep 2, 2015 10:27 PM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
