'91 LO3 to a '88 to '92 truck motor
Old Jun 18, 2002 | 01:59 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
I have a '91 RS with a crappy 305 tbi, and I know of a 350 engine out of a 88 - 92 chev. truck that has the center mount style valve covers and heads. So what I was wondering is if I use my 305 tbi on the 350 truck motor what will I need to do to boost the air fuel mixture? Is it as simple as getting a performance chip and that's it? IF so where do I get one?
Any help is greatly appreciated.
Thanks, Garrett
Old Jun 19, 2002 | 09:02 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
You might be able to run it with just a fuel pressure increase, but it's better to have the 350 TBI Truck Injectors, and fine-tune with pressure.Best to have a chip and correct injectors with adjustable pressure regulator. I'm running a 300 HP 350 with TBI, truck injectors, Turbo City Throttle Body and AFPR and a custom chip.
My custom chip is from Ed Wright Automotive, (Fastchip.com)
-Rich-
jhawkeye
May 25, 2022 06:33 PM
tricky1
Aug 23, 2015 01:17 PM
squiggy2
Aug 9, 2015 09:30 PM
mustangman65_79
Aug 8, 2015 01:18 AM
