What cam should I use?
Old Jul 11, 2002 | 12:41 AM
Raggy67's Avatar
I've got a 91 z-28 305 tpi.
It's got K&N intake, Pulley system, MSD ignition, 8.8mm wires, Helical intake spacer, High performance muffler & a Super Chip.
I guess it's putting out around 250-275hp.
I'd like it closer to the 350-375hp area, my budget is limited and a set of heads are probably too much.
But a good cam is another possibility.
Any other ideas are welcome, third gen are the Best.
Old Jul 11, 2002 | 08:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd guess it's putting out closer to 215 HP.
Put in the biggest, baddest computer-compatible cam in it, adjustable fuel pressure regulator, you'll probably get up to 250 HP.
Headers and high flow exhaust - maybe 275.
Ported heads and larger intake valves (either your current heads or World Products S/R Torquer 305 heads), ported plenum, larger TB, shorter/fatter runners, custom PROM - perhaps 300-325.
Want more than that, with TPI, you're looking at mucho buckos. Probably easier to just go with a 350.
Old Jul 12, 2002 | 12:57 PM
Raggy67's Avatar
Gee the stock 305 puts out 205hp, and your saying that with all the mods its only putting out close to 215.. including a superchip..
maybe I should waite for another reply.
Old Jul 12, 2002 | 01:20 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You would be lucky if you got any gain with a Superchip.
Old Jul 12, 2002 | 01:43 PM
five7kid's Avatar
Re: What cam should I use?
...Helical intake spacer...
That probably cost you 5 right there...
Old Jul 12, 2002 | 02:14 PM
ATOMonkey's Avatar
You can't honestly expect an old engine to run better than new because you put on a new air filter.
Seriously, do what the kid says and buy a cam that won't completely freak out the computer. Then get a set of heads that will work on a future 350 and take the hit on compression. Better flowing heads will make up for the loss of a couple of points. I recomend World sportsman or sportsman II, or if you can't foot the bill, Vortec heads are a good value. Getting the TPI base to fit right is a challenge, but I think the edelbrock sell a Vortec specific base now. I could be wrong, not that into TPI. After the heads you need to get like a stealth ram or something of that nature that is tuned for higher RPM operation. All of these parts are 350 compatible, so it's not like you're pissing away all of your money.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
