Going rates at machine shops.
Old Jul 12, 2002 | 09:47 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I live in NJ and know of a few shops but every time I ask them for a quote they want the engine there before they say anything. I have taken out the pisons, rods, cam, crank...it is esentially bare. I would like to know how much the following will cost: Hot tanked, bored .030 over (with plate), new cam bearings, and plugs, should it be sonic tested? (did I miss anything?). I will later need to have the pistons, rods and crank balanced but I will be installing that myself (depending on how much that would cost to install. A book I read recently (1998 prices) said that the block work would cost about $500. does that sound about right?
Edit:
*I don't think you can get blocks magnafluxed*
Old Jul 12, 2002 | 09:54 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I would say more like $350 - 400 here in PA.
Old Jul 12, 2002 | 09:55 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
When I had my LT1 done up they did .030 overbore with plate, hot tank, pressed new pistons onto rods, install frost plugs, and check deck height it cost me $305 tax ncluded. I do not know how much magnafluxing costs so I can not say.
Old Jul 12, 2002 | 12:07 PM
ede's Avatar
ede
you can get anything that's feromagnetic mag tested. here the price would be:
40 to clean
15 to install cam bearings
10 for freeze plugs
8 dollars a hole to bore hone w/plate
don't think anyone around here does UT testing, i've done my own and not sure i'd trust anyone at a machine shop to do it, it's hard to get sound in a casting and get a good signial. i know machine shops do it every day but i'd suspect how accurate they are.
Old Jul 12, 2002 | 01:08 PM
Ricktpi's Avatar
40 to clean
10 for freeze plugs
If these prices are accurate it would pay me to drive to Ohio.
Old Jul 12, 2002 | 01:25 PM
Omega's Avatar
Engine: LS1 / LS3
I found these prices at a Race shop in Patterson... he said he doesn't work with "normal" rebuilds... sounds like he is a *****...
Block strip & boil $65
Install cam bearings $32
Install oil & water plugs $20
Bore up to .030" $92
Hone 820 finish w/stress plate $125
Check align bore $40
Total $374
That doesn't sound too bad but this is assuming the block is good. The block I have was supposedly from a late 80's vette that "pissed oil out the dipstick" when a SC was added. I took the oil pan off and the oil pump had exploded. The guy took out some of the parts but chunks of the cover plate on the pump were in the pan. It is also a 2 bolt main block (I thought all vettes had 4 bolts?) Other than that it seems to be in good shape.
Old Jul 12, 2002 | 02:36 PM
ATOMonkey's Avatar
Vettes haven't had 4 bolt blocks since way back in the day, and the LS1 of course. You're lucky you didn't pitch a rod if the pump was broke. I hope that block cleans up at .030 over. You might want to think about splayed mains while you're in there. Just a thought.
Old Jul 12, 2002 | 11:38 PM
rickyzZ28's Avatar
Car: 1990 RS
All LT1 and LT4 vette blocks have 4 bolt mains and I dont think those are from back in the day.
Old Jul 13, 2002 | 05:42 AM
ede's Avatar
ede
rick it doesn't include the price of the parts. yeah it gats me every time i read what some of you pay for machine work. funny thing is it's the only machine shop within 40 miles or so, thay could charge a lot more.
Old Jul 18, 2002 | 01:00 PM
1986redbird's Avatar
I'm getting my block: bored (30 over),tanked,fluxed,cam bearings,freeze plugs,honed and crank: tanked, checked,turned (10/10) and polished for $ 250.00. I live in Va. beach.
just put it in the shop this morning !!!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
