L98 to Lb9
Old Jul 20, 2002 | 06:19 PM
caleb's Avatar
Car: 89' Iroc
L98 to Lb9
I am looking at buying an 89 IROC that has a 350 TPI (L98) engine in it, the cam has a flattened lobe and needs to be replaced. I have an 85 305 TPI (Lb9) From my 85 Iroc that i totaled, i talked to a mechanic friend of mine, and he said that I should swap engines then rebuild the 350 and keep it for a back up for when the 305 dies. My question is this-----------------------
When my car was totaled, the alteranter was busted, and most of the pullies got bent, so will all the pullies from the L98 fit onto the LB9 ? Will the distributer work with the LB9?
Thanks in advance
Old Jul 20, 2002 | 11:32 PM
caleb's Avatar
Car: 89' Iroc
come on someone has to know the answer to my question!
Old Jul 21, 2002 | 03:17 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
There should not be a problem with brackets or anything like that since both engines are TPI. However, I recall that the harmonic balancer is larger on the 305. Secondly, take the 305 prom out of your ECM and swap it with the new one. When you go back to the 350 you can swap it back.
Hope this helps.
BILL
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
