Whats wrong with 882 Heads?
Old Aug 5, 2002 | 01:48 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I recently saw a post that said 882 heads are bad. I have 882 heads on my non-original 350, whats wrong with them? What years were they made & what motors did they come on?
Old Aug 5, 2002 | 07:37 AM
ede's Avatar
ede
they're large chamber smog heads try www.mortec.com
Old Aug 5, 2002 | 08:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are typical terrible smog heads; one of the main ingredients in the combinations that produced 170 & 189 HP 350s in the 70s. They came on 350s and 400s, 2 and 4 barrel, all through the mid to late 70s, in every chassis that 350s came in. They used the same short block in all of them, the same cam (the "929" cam), the same exhaust, and those heads, and then just stuck either the 2-bbl or 4-bbl intake and carb on it. Yuck.
They can be made to flow fairly well with porting but end up with some very thin places that are even more prone to cracking than they already are. Plus, like ede said, they have large combustion chambers so it's difficult to build a reasonably high compression motor out of them. You have to use dome pistons which reduced both the combustion and thermal efficiencies of the finished product.
Get rid of them if you want your car to run halfway strong.
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
Cornholio7979
Sep 20, 2018 02:31 AM
soarestransam
Aug 24, 2015 08:15 AM
dhonda200
Aug 11, 2015 11:50 PM
