What oil pan are you running with your y-pipe???
Old Aug 7, 2002 | 07:52 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I am going to be putting a ZZ4 shortblock in my '89 Iroc-Z with SLP 1 3/4 headers soon and need a recomendation on an oil pan. I have searched the boards and have only found that the Moroso 6QT #20182 will fit but I need to crush the y-pipe in some areas. I dont want to restrict the y-pipe. Also it seem that the Moroso pans are not of great quality. Whats a good quality pan????? Whats everyone use with SLP 1 3/4 headers??? Would it be better to get one with a windage tray...what exactly does it do???? Or should I just reuse the stock one?????
Old Aug 8, 2002 | 07:29 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Why would you want to replace the oil pan? It should bolt up with no problems but I could be wrong.
Old Aug 8, 2002 | 07:38 AM
ede's Avatar
ede
i guess i'm confused too any SBC oil pan that works with your block will clear the y pipe. are you wanting larger capacity pans? hambuger makes some real nice pans and can make you a custom fit pan if you need it.
Old Aug 8, 2002 | 08:40 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I run the Moroso pan with my SLP 1.75" headers and only had to dimple my y pipe in a few areas to clear..not crush.I have no problems with the pan fitment or quality at all,I have always run Moroso pans on past motors with the same results.
Old Aug 8, 2002 | 08:59 AM
Dragula's Avatar
I am using the Milodon for 86 and earlier Camaro's with the two-piece seal. They also make one for the one-piece seal.
No dimpling necessary on mine.
Old Aug 8, 2002 | 09:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Since the SLPs locate the Y-pipe in the same location as the stock one, anything that will work with the stock exhaust should work with the SLP...
I'm running the 71-73 Z28 6-quart system windage tray pan on my 400 with the Edelbrock TES for L69 (big Y-pipe), excellent fit.
Old Aug 8, 2002 | 10:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm running the ZZ4 pan and baffle (SDPC had a take-off special last year). I don't have SLPs, but my y-pipe fits in there just fine.
That extra quart of oil isn't doing you any good. Deeper pans were needed back in the days when dyno juice was the best oil available, but that certainly isn't the case any more. If you want extra oil going through the system, put on a remote mount filter with two elements and an oil cooler.
Old Aug 9, 2002 | 01:02 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Call me crazy but i though thirdgens had a fairly specific pan they used. IE a truck pan wouldn't fit it.
i've been wrong before.
Old Aug 9, 2002 | 01:47 PM
Dragula's Avatar
Yep......there are some SBC oilpans that will not fit our cars correctly.
Old Aug 9, 2002 | 02:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... a truck pan won't, and an older full-size won't. The ones from an A or G body will. They started making all the car ones the same at some point, in the mid 80s I think but I could be wrong; so after some year yet to be accurately specified, any car one will fit.
Old Aug 13, 2002 | 09:31 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the TD Slam-Guard Pan.
Basically a stock size pan with a thick skid plate welded onto the sump.(My car's very low). My SLP Y-Pipe clears without any dimpling or flattening, but it's close.
http://www.tdperformance.com/ppdir_21.html
-Rich-
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
