Planning BBC swap
Old Sep 5, 2002 | 12:37 PM
87z28TN's Avatar
Car: 1987 Camaro Z28
Planning BBC swap
As does everyone, I have a couple questions concerning a BBC swap. I was planning on using either a 427 or 454.
Question 1: I will still use the car on the street, so I want an O/D tranny. I hear that the 700R4 is not good for use on a BBC, what are my options?
Question 2: Is a BBC suitable for just a nice streetable car?
Thanks in advance.
Old Sep 5, 2002 | 02:18 PM
jimmbo's Avatar
yes a bigblock can be quite streetable
although you will sacrifice in the mpg dept.
do not i mean do not put a 700r4 behind a big block
(matter of fact never use one period they are junk)
try a 4l80e if you can afford one
have you found a motor and what are you looking for?
jimbo
Old Sep 5, 2002 | 02:22 PM
87z28TN's Avatar
Thanks for the reply. No I haven't found the motor yet. I was going to do serious looking once I found out if it was a good idea. By the way, how much are we talking for the 4l80e tranny?
Old Sep 5, 2002 | 03:38 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've been running mine for 4+ years now and love it. No overdrive (T400) and 3.73 gears doesn't make for good mpg's on the highway, but that's not why I built it More info is on my page at www.koolmeister.com
Miles
Old Sep 5, 2002 | 07:14 PM
87RS402's Avatar
Question #2 is an easy answer, yes.
Question #1 is a little different. Your choices for OD transmissions are limited to the 4L80 and a manual. There are several OD manuals out that will hold a BBC but don't be shocked when you see the price tag, figure in the car costs of around $2k if you go with a used 4th gen T-56.
Old Sep 6, 2002 | 03:48 PM
jimmbo's Avatar
are you still loking for a motor ?
i got a 468 in the classifieds under aug 16th
or you can email me at jimme25@hotmail.com for more info
i also have the th400 trans and ati converter that worked very well with this combo
the motor trans and converter are not just some rebuilt piece they are all top notch
and have the best parts in them
thanks jim
Old Sep 10, 2002 | 05:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You could always use a TH350 or TH400 tranny and have a Gear Vendor OD installed on the back of it.
Old Sep 10, 2002 | 06:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
4L80E is essentially an electronic TH400 with an overdrive. It's an enormous transmission and likely would not fit without hassles. A gear vendors overdrive can be used behind a TH400 but don't get hard on the throttle when it's in overdrive.
A manual tranny is another option. You will be confined to some of the more expensive overdrive trannys on the market.
Old Sep 10, 2002 | 08:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What do you mean, "...don't get hard on the throttle in overdrive"? Gear Vendors' biggest customer base is motorhomes, 10-ton beasts with big blocks ahead of them. You can be sure they don't heed that advice!
Another OD choice is TH200R4. Pro Built sells 'em, get a Spohn crossmember/torque arm kit, good to go. If 10-sec GN's can abuse those trannys with impunity, a BBC shouldn't hurt them, either.
Old Sep 10, 2002 | 10:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That's TH200-4R
Old Sep 11, 2002 | 10:26 AM
five7kid's Avatar
Mna, I haet ti wehn I od taht...
Old Sep 11, 2002 | 04:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
while were on the subject of a 200 r4, anyone know what they can be built to take ? My friend has one sitting under his workbench just collecting dust. Id prefer torque #'s. Im looking for a cheap alternative to get a new tranny to replace my ailing 700R4. It would be nice to have a second trannyto work on while still having the car operational.
Old Sep 11, 2002 | 04:55 PM
Car: 88 Camaro SC
Engine: SFI'd 350
to add to this, id like to build a nice drive train to go ewith my eventual mods wile not having to disturb the car untill im ready to bold everything on. After all, this is my daily driver.
Jorlain
Aug 24, 2022 05:11 PM
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
sreZ28
Aug 14, 2015 07:48 PM
