305 350 Question
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
305 350 Question
Can I put my 87 305 intake maninfold on my 77 350 motor? thnks
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Is your 305 carbed and are you going to carb your 350? Yes the intake would bolt up, even if it is a TPI motor, but you may want to consider whether it is going to have the air flow you want. Aftermarket intakes don't cost that much. In the case that your 305 is TPI and you want to use that, you will prob have to get a 350 chip for your ECM or reprogram the existing one and get higher volume injectors to handle the extra cubes.
Car: 1988 IROC-Z
Thnks and srry its carbed. And I just need it on the road right now dont care about performence right now. Next spring Ill worry about that.
Re: 305 350 Question
Well if you are not concerned about performance then just freshen up the 305. That would be the most cost effective. Just save your money for the 350 if you want to eventually swap it. Then you can make it a worthwhile swap.
Car: 1988 IROC-Z
I dont know what Im gonna build up but not the 305. right now I need it to commute with. next year Ill take it off the road and and put in a new crate motor. all of my money is tied up right now so I just need to get it on the road quickly and without dumping $$ into a motor Im gonna replace anyway. thnks
Car: 1988 IROC-Z
Ok my buddies got an edelbrock intake for me $30 cant complain. and itll bolt right on. he had it on one of his vettes . its just dirty. Ill just glass bead it and itll look like new. thnks again.
NinjaNife
Aug 23, 2015 11:49 AM
