377 ci internals
Old Sep 27, 2002 | 07:44 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
377 ci internals
Does anyone know if the stock 3.48 crank and 5.7 rods off an L98 or LB9 will work on 400sbc ? In other words to you have to buy a special crank for a 377 or will any standard sized 3.48 crank and 5.7 rods work ?
thx,
RP.
Old Sep 27, 2002 | 09:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The crank has to be for a 2-piece rear main seal; so a L98 crank won't work. Has to be the earlier model 350 crank.
But apart from that, yes, it works. Use a 400 block, stock 400 pistons, stock 350 crank & rods, and bearing spacers which you can buy from Comp and maybe others.
Old Sep 27, 2002 | 07:30 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
If you really wanted to, you can get an adapter to run a 1 pc. in a 2pc. block. Last i looked they were about $130, so it might not be cost effective to reuse an old crank if it needs machine work.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sreZ28
Oct 22, 2015 08:21 AM
mfp189
Sep 27, 2015 09:25 AM
84redta
Sep 19, 2015 09:58 AM
scottmoyer
Sep 7, 2015 07:06 PM
