3.1 to 3.8 swap
Old Oct 13, 2002 | 07:34 PM
777ZLLL's Avatar
3.1 to 3.8 swap
Ok guys im trying to make up my mind here... i need some help.
My 3.1 just isnt cutting it anymore. Im gonne be keeping it for a while longer though. Umm i need to know how hard it would be to install a 3.8 out of a newer bird or camaro. Many people have told me that an LT1 is really hard. Is the six just as hard??? I want atleast 220 hp, and over 20 mpg.. i know thats a lot to ask for, but thats my goal.... Someone please help me out.
thank
Old Oct 14, 2002 | 05:42 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the 3.8 will be just as hard to install as the LT1
i would go with the LT1 IMHO
Old Oct 17, 2002 | 06:39 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
As far as I've hear, the 3.8 doesn't have the engine mounts in the same place as the 2.8, 3.1, 3.4 engines. So you'd have to drill new holes for the motor mounts. The LT1 on the other hand mounts in the same place as any 350, and the holes for the motor mounts are already in your engine bay. The 3800 series engine (which is what was in late model f-bodies) was rated at 200 hp, so if you're wanting a minimum of 220, you'd have to do some mods even to the 3.8 to get there.
Old Oct 22, 2002 | 12:11 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i wouldn't go that far, not sure if the later 3.8's changed mount locations(they probably did) but the turbo 3.8 actually used the holes already drilled in the crossmember for the 2.8 and 3.1 motors, I was a bit surprised...
Old Oct 22, 2002 | 02:41 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
I remember a while ago someone had asked about this and the general consencious was that the newer 3.8 did not mount in the same location. And of course you'd have other things to consider like OBD II. But if the 3.8 that was in TTAs would have the same mounts, and bolt up to a v6 tranny, that might be the way to go. Although was the 3.8 a 90* V as opposed to the 60* of the 2.8/3.1/3.4 engines?
Old Oct 22, 2002 | 02:45 PM
fly89gta's Avatar
Car: 2018 Camaro SS
i figured the newer ones would have different mounts
a 60* V6 700r4 will not bolt up to the 3.8...since the 3.8 is a 90* motor..
AussiePr0nCar
Mar 6, 2020 04:04 PM
neilb
Oct 4, 2018 12:36 AM
theshackle
Aug 22, 2015 06:52 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
