Does-anyone-have-desktop-dyno-2000
Old Oct 21, 2002 | 09:16 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
I-AM-ASKING-BECAUSE-I-WOULD-LIKE-TO-HAVE-AN-ESTIMATE-ON-WHAT-MY-ENGINE-IS-MAKING
I-HAVE-A-350-BOARED-.040-OVER-WITH-A-488-LIFT-CAM-CHEVY-461-DOUBLE-HUMP-HEADS-W/-1.94/1.5-VALVES-ACCELL-45000-VOLT-COIL-ACCELL-DISTIBUTOR-HEDMAN-SHORTY-HEADERS-A-PERFOMER-INTAKE-A-HOLLEY-600-CARB-IF-THERES-ANYTHING-ELSE-JUST-TELL-ME-SORRY-ABOUT-THE-DASHES-I-RATHER-SPEND-MONEY-ON-MY-CAR-THEN-ON-MY-KEYBOARD-SPACEBAR-BROKE
Old Oct 21, 2002 | 09:38 PM
87Formula4bbl's Avatar
Car: '87 Formula
You can get a brand spankin new keyboard for about $9 if you look, probly at Best Buy
Old Oct 21, 2002 | 09:52 PM
87RS402's Avatar
AND-THE-CAPS-LOCK-KEY-MIGHT-WORK-TOO!
Old Oct 21, 2002 | 09:56 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Transmission: th350
OK-BUT-I-DIDNT-ASK-HOW-MUCH-A-KEYBOARD-COSTS
Old Oct 21, 2002 | 11:31 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
HA-HA-HA-
HOW-THE-HELL-DO-YOU-GET-BY-TALKING-LIKE-THIS?
SORRY-THIS-IS-TO-AMUSING
Old Oct 22, 2002 | 06:37 AM
ede's Avatar
ede
damn this a good thread, hell while you're out keyboard shopping you might be able to find DD2000
Old Oct 22, 2002 | 09:45 AM
2laneblacktop's Avatar
I will run it through the Dyno if you can give me alittle more info. I need compression ratio, cam lobe seperation, cam duration, and IVO, EVO, IVC, EVC of your cam. And tell me what cam you have like the brand name and such.
Old Oct 22, 2002 | 01:32 PM
Guest
Guest
Posts: n/a
Are you guys having fun here?
Old Oct 22, 2002 | 02:56 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Transmission: th350
it-has-a-10.3:1-compression-ratio-the-cam-should-be-a-crancams-the-summit-part-number-is-(crn-100072)-Specifications:
* Advertised duration: 284 intake/284 exhaust
* Duration at .050 in. cam lift: 228 intake/228 exhaust
* Gross valve lift: .480 in. intake/.480 in. exhaust
* Lobe separation: 112 degreess-the-specs
thanks-if-theres-anything-else-just-tell-me
Old Oct 22, 2002 | 03:53 PM
I ran your engine, and because I didn't have your exact numbers for IVO, EVO, IVC, EVC I ran some different combos through it where they are likely to be. Everytime I ran it I came up with about the same readings. Here they are:
Open headers:
HP 375-390@5500rpm
TQ 390-405@4500rpm
With exhaust:
360-370@5500rpm
375-390@4500rpm
Of course this is a computer simulation and thats the best idea I can give you. In reality it could be somewhat lower or higher. This is just an estimate but you already knew that...haha. Looks like a good combo. Hope this is what you kinda expected.
Old Oct 22, 2002 | 09:31 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Transmission: th350
2laneblacktop-thanks-i-was-only-really-expecting-around-300-but-ill-be-more-than-happy-to-take-that-it-looks-like-i-wont-be-sellin-this-engine-now:hail:
Old Oct 23, 2002 | 08:34 AM
DLTrahan83's Avatar
i can't find Desktop Dyno 2000 or later anywhere where i live.
I can't find Desktop Dyno 2000 or later in my area. If anyone has the full version let me know. How much does it cost anyway? I would like to purchase a burned copy.
Old Nov 6, 2002 | 04:55 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Transmission: th350
I-just-got-it-too-but-i-have-one-question-what-does-ivo-ivc-evo-evc-stand-for-im-lost-on-that-part
Old Nov 6, 2002 | 06:51 PM
kevinc's Avatar
Car: 1982 Z28
The acronymns refer to specs you get off the cam's card:
Intake Valve Open
Intake Valve Close
Exhaust Valve Open
Exhaust Valve Close
Predicted next question from SMOKY21:
"WHERE-DO-I-FIND-THIS-INFORMATION? MY-CAM-DIDN'T-COME-WITH-A-CARD."
Answer: Call the cam's manufacturer's tech support line, or if it's a Crane you can look it up on their website.
Old Nov 6, 2002 | 10:01 PM
rezinn's Avatar
You accidentally inserted some spaces a few posts ago after * and :, and you could easily copy and paste a space if you really wanted to. Also, if you can't fix a keyboard, I wouldn't bother working on a car. You can get a keyboard for $5, if you can't afford that, why are you spending money on your car?
P.S. What does BOARED mean?
DLTrahan83: It's illegal to purchase burned copies of anything, don't attemp to do that here.
Old Nov 6, 2002 | 10:09 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Transmission: th350
Well-just-for-your-info-im-almost-done-with-my-car-and-what-do-computers-and-cars-have-to-do-with-each-other.-I-use-a-computer-to-look-up-info.-I-dont-want-to-buy-a-keyboard-since-i-know-that-it-pisses-dumba$$es-like-you-off.
ps-i-got-a-couple-of-buddies-who-can-say-that-i-know-my-****-actually-better-then-most-guys-triple-my-age-and-im-only-17
O-ya-out-hear-in-Chicago-we-do-stuff-a-little-different-then-you-guys-from-the-land-of-fruits-and-nuts:lala: :lala:
Old Nov 6, 2002 | 10:27 PM
Guest
Guest
Posts: n/a
Wel, that wasnt really necessary. I guess I gotta lock it now.
