View Poll Results: Worth it Yes/No ?
Yes. Go For it
70.00%
No. Keep Looking
30.00%
Voters: 20. You may not vote on this poll
Good Deal Yes/No ?
Old Nov 17, 2002 | 02:02 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Good Deal Yes/No ?
this is a 383 crate motor for $3199. It makes 414hp@6000 and 452tq@4500, parts include :
GM 4 bolt main 350 block (4.030 bore size)
New Eagle std/std cast steel "stroker crank"
Eagle forged rods
TRW hypereutectic pistons (10:1 comp)
Crane 284 hydraulic flat tappet camshaft (488 lift, 228@50)
Heavy duty Cloyes double roller timing set
Michigan 77 bearings
High volume oil pump
Fel-Pro gaskets
World Products "Sportsman II" heads
Hard seats and guides for unleaded or reg fuel
New 2.02" stainless intake valves
New 1.60" stainless exhaust valves
Screw in studs and guideplates
New Pioneer heavy duty springs
New pushrods
Crane Cams roller rockers #11744
New oil pan, timing cover, chrome valve covers
New GM harmonic balancer damper
New heavy duty flexplate (standard trans. flywheel extra)
Edelbrock Performer RPM intake manifold #7101
Balanced, blueprinted and longblock assembled
Worth it Yes/No ?
Old Nov 17, 2002 | 02:56 PM
ede's Avatar
ede
who built it? lot of parts in it i wouldn't use, it sounds too cheap to me.
Old Nov 17, 2002 | 03:39 PM
MdFormula350's Avatar
who built it and what kinda warrenty?
not that much money for that kinda numbers!
Old Nov 26, 2002 | 11:17 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Where did you find this deal? I am also in the market and currently evaluating different options. New crate or rebuild of existing assembly.
Old Nov 26, 2002 | 07:08 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
a company called AllChevy
Old Nov 30, 2002 | 04:56 PM
Car: YTG Camaro
Engine: 383
I reviewed the web page. Any idea on their warranty or balancing tolerance?
Old Dec 1, 2002 | 01:19 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
i really haven't asked but you can e-mail them the respon prety well. i have asked them many question this way but somtimes it takes a day to get a response.
Old Dec 1, 2002 | 07:55 AM
Z28DJP1987's Avatar
Small shop that custom bulids your motor. One year warranty on engines and blancing spec just ask them.
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ChevyZ71
Aug 13, 2015 07:30 AM
