Looking for a wiring harness to swap in a LT1
Old Dec 2, 2002 | 09:31 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
I have a 95 LT1 I have seen the painless harness in jegs but will it just plug into my 91 RS? or will I have to wire all my gauges up . That is the only thing I am really worried about is getting the spedo tach oil and fuel temp gauges to work. Any info will be Helpfull Thanks Sean Car is a M6 if that matters.
Old Dec 3, 2002 | 07:23 AM
BirdPower's Avatar
I have just completed an engine swap and i did not use the wiring harness.It is from a 94 Trans Am and it is from the computer to all the sensors.The onlt thing that is missing is the connector for the AC compressor. Make me an offer $$$
Old Dec 3, 2002 | 05:52 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Not really what I am looking for but thanks for the offer. What harness did you use?
Old Dec 4, 2002 | 04:10 PM
mat89RS's Avatar
Hi, as per your wiring harness and gauges, it will be easy to do, All you need is a haynes or chilton and to know which wire is which at the 2 ECM connectors of your camaro. it will be a bit hard to wire the VSS (vehicule Speed Sensor) since it runs on a realy by it self.
the LT1 wiring harness is easy to work with, as per the gauge there's 8-9 wires altogether to plug and you're in business, they are only signal wire, not powering everything in the dash .
Ask me if you need more help .
Mat
Old Dec 5, 2002 | 05:34 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I mad emy own, not hard to do and you get exactly what you want. The only thing I am unsure of on your car is the electric speedo drive.
Buy a manual that covers the LT1 wiring, or search for the computer pin outs on the net. Keep the wires that you will require for which functions you want your LT1 ecm to provide and remove the rest of the wires from the harness starting from the ecm end. Pretty simple!
Your other guages will work directly with the ones on the LT1 except maybe the oil pressure sending unit, use your old one.
Old Dec 7, 2002 | 02:30 AM
SuperchargedRS's Avatar
Car: Camaro of course
go to http://www.hotrodlane.cc they have them, they require no cutting of the wires, which yelds much more of a pro look and feel to the swap.
Old Dec 7, 2002 | 11:42 AM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
I sent them an email.thanks for the link
Old Dec 8, 2002 | 08:11 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I have the Painless harness part #60502. If you go to http://unitsn4.cz28.com/ you can see a pic of it. I got it from Year One's Next Gen Parts Division with a 20% off coupon for somewhere around $375 shipped.
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
