How does this rebuilt deal look??
Old Dec 7, 2002 | 02:26 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
PRICE: $1129.00
"What is the description of engine long blocks?
All long blocks come with cylinder head(s) attached and valve train installed. Valve covers, timing cover, intake manifold and oil pan are not included.
All long blocks have NEW valves, valve springs, valve keepers, push rods, rocker arms, fulcrums, lifters, camshaft, timing chain (belt), timing gears, valve guides (diamond honed), three angle seats, cam, rod and main bearings, pistons, piston rings, rod bushings (if applicable), gaskets and oil pump.
All cylinder blocks, cylinder heads, crankshafts and connecting rods are cleaned and shot peened and magnafluxed for cracks. All bolt holes are tapped.
Cylinder blocks are bored to each piston and diamond honed to 18RMS finish. All oil galleys are hand brushed with white cleaning brushes and cylinders are hand cleaned with cleaning solution and white towels.
Cylinder heads have each valve guide diamond honed, seats are three angle. After assembly, heads are vacuum checked for valve seating.
Crankshafts are ground and polished to 12RMS. Each oil galley is hand brushed with a white cleaning brush.
All connecting rods are honed.
ALL OUR REMANUFACTURED LONG BLOCKS MEET OR EXCEED ORIGINAL EQUIPMENT SPECIFICATIONS"
Old Dec 7, 2002 | 02:31 PM
picture of it
lets see if it works:
http://www.rebuilt-auto-engines.com/.../gmc-305lb.jpg
Old Dec 9, 2002 | 09:52 AM
MdFormula350's Avatar
not bad!
Old Dec 10, 2002 | 12:26 PM
allright then....prob wont be until spring until I can ease that sucker in. But, this way I can afford to get the headers to go with it. Woopie!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Veaceonee
Sep 29, 2016 08:15 PM
DARKmj16
Sep 9, 2015 04:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
