LG4 - 7X 350 flywheel question
I am swapping my LG4 motor for a 350 4 bolt out of a late 70's truck. I have a T5 tranny (no laughing
). I know I need a new flywheel due to the seal difference, but I am not sure which to get. I will be getting it from the local Napa, but they aren't sure which one to give me. Does anyone have a Napa part number for this flywheel? Thank you!!!
I did the same swap, what you want is a 153 tooth (12-3/4") flywheel for a 2 piece rear main. If they're the normal parts counter idiots and want to know what kind of car your working on tell them it's an 85 Camaro with a 305.
Oh and bend over while your there, your gonna get the shaft and they won't even kiss you after. If you want to find one cheaper call around to the junkyards like I did, got mine for $75 shipped. Or you can get a lakewood bellhousing PN# 150020 (around $250) and use a standard 168 tooth (14") flywheel with the standard 11" clutch.
Car: 4
Engine: 6
Transmission: 5
86 will use the one-piece crank.
I don't know tha NAPA # off the top of my head. Have you tried www.napaonline.com yet? 86-92 305 5-speed Camaro or Firebird V8.
I have one but I'm keeping it.
