LS6 in my 86 trans am
Old Dec 13, 2002 | 04:55 PM
mike2468's Avatar
hey guys will a 2003 LS6 fit right in or will i have to do some work to the motor mounts. im getting one that has it all..for about 4000 bucks but before i lay down the jack i want to know what you guys think
Old Dec 13, 2002 | 06:00 PM
pskel350's Avatar
Well i am not gonna lie to you, it is a very hard swap, but it can be done. I am not sure if any one has ever swapped in a LS6, but people have swapped in LS1's which should be about the same exact swap. I would do a search on swapping LS1 and go from there. I am sure people on here have much more knowledge then me and will be able to help you out a lot more. Good luck on the swap, and i am sure it will be badass when its done.
Old Dec 13, 2002 | 08:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, externally, an LS6 has the exact same dimentions as an LS1, so it should be the same as an LS1 swap. I'm pretty sure that the only difference between an LS6 and LS1 is that the LS6 has a better intake system, and (not 100% on this) a better cam and compression ratio is slightly higher.
Old Dec 14, 2002 | 12:43 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I believe the LS6 also has better heads, not 100% sure though. Just read it somewhere.
Old Dec 14, 2002 | 01:19 AM
Black92Z28's Avatar
Check out this website,
www.speartech.com
They show a swap of an LS1 into a 3rd gen, could be useful to you.
Old Dec 15, 2002 | 03:19 PM
MdFormula350's Avatar
that was an awesome project they did!!
Old Dec 15, 2002 | 10:47 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Monte LS1
Old Dec 23, 2002 | 12:24 AM
Kandied91z's Avatar
yeah it can be done, just need to make sure you also have the harness, computer, trans, etc.
i looked into it myself as well. figured with the LS6 a little bit of goodies added to it; the trans, computer, etc i was looking at at least 6-8000 for under 400 ponies. quite a bit of custom work. definate motor mounts need to be made as well as some alterations for the electronics.
scraped the idea and now i'm going to try a crate engine. may not be as cool or upto date with technology but when it has more horsepower and money in the pocket i'll be happier. the only upside i see with it (besides being able to say you have an LS6) is that it's lighter. other than that the parts are extremely expensive when compared to you basic 350.
good luck with it though. hope you have the pocket book to do it right.
Old Dec 23, 2002 | 01:34 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I was in the market for an LS6. However I went with a 2001 LS1 and modded it instead. The 01 and 02 LS1 share the same free flowing intake as the LS6. Through cam, pushrod, springs, and PCM recalibtation I expect to match LS6 RWHP.
From my experience, the LS6 demands at least a 2K premium. That money can be better spent on mods.
Good luck
BILL
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
