14 or 15 gallon tank?
i am doing an lt1 swap in my 87 lg4 z28. i need to replace the gas tank and pump. when i went to the parts store i had 2 choices. 14 or 15 gallon tank. which do i get. also i believe on came with a filler neck and the other without.i need to know so i can get it ordered. thank you
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
If they all fit the same way.. its all up to you.
Id get the biggest one.
The stock one is 15.5 gallons, so ..
Engine: 3.0L/183
Im sorry, I dont know.. they shoud have
the specs at the store.. theyll tell u..
But i mean the stock size is 15,5 gallons..
why change it ?
(maybe im wrong)
Good luck
why change it ?
(maybe im wrong)
Good luck
4th gen tank
I read around on these board, that the 4th gen tank is good as it is a direct fit and it is lighter (plastic?) and I believe is still a good 15.5-16 gallon tank.
Should look into that.
Engine: 3.0L/183
Yup... its plasitc.. ligther..
Id get that..
Id get that..
i've heard that it doesn't fit in a 3rd gen. if it does somebody give me some affirmation on it. i already have a 4th gen tank and pump. that would save me about $250 if i could use the 4th gen one
