2 Piece Rear Main to ONE Piece Seal
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i want to buy a complete 383 stroker kit (pistons, rods bearings, etc.) from summit but it comes with a 2 piece rear mail seal and i will have a 1 piece rear main block can i just buy another one piece seal to get everything to work properly or is more stuff different for 2 piece seal kits???????????????
novice engine builder here!
Car: 1991 Z28
Engine: 383
ok cause i can find the kit to match what i want but most seem to come with a 2 piece seal i was just wondering if i could just go out and but a one piece seal for the kit to fit my engine.
Transmission: 4L80E/4L80E
The "cheap" stroker crank cores are factory 400 parts, all of which were 2-piece rear main seal. Take a trashed 400 crank, turn the journals down to 350 size, now you have a 383 crank.
One-piece rear main seal stroker cranks have to be new castings/forgings. That'll cost you more.
The alternative is to get a two-piece crank and an adapter to use it in a one-piece block - about $100.
The flexplate/flywheel is also different between one- and two-piece rear main seal cranks.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
