How to tell difference between 305 and 350?
Old Feb 11, 2003 | 09:43 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
is there actually a way to tell the difference between a 305 zand a 350?? my buddy bought a car and according to the vin he has a L69 305 but the engine was completely rebuilt and we think its a 350.. please help.
Old Feb 11, 2003 | 11:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Casting number.
It's above the bell housing mount behind the driver's side head. A lot of fun to try to read. But, that's the only real way to tell short of disassembly and measurement (although I suppose you could do a wet displacement test).
Old Feb 12, 2003 | 07:57 PM
Car: 1984 Z28
and what exactly is a wet displacement test.
do all engines have that number on them?? or just stock ones.
Old Feb 12, 2003 | 08:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All blocks have casting numbers.
A wet displacement test is where you take a spark plug out, and put that piston at BDC, and take both rockers off that cyl, and fill it as full as you can get it with oil, then turn the engine to TDC, and see how much comes out.
Here's a pic of a block casting #. It's on the top of the bell housing flange behind the driver's side head. Right out in the open in plain sight (yeah right)
Attached Thumbnails How to tell difference between 305 and 350?-head-casting1.jpg
Old Feb 12, 2003 | 09:30 PM
Car: 1984 Z28
maybe it would be a little easier to check fo rtha tnumber instead of that test thing.. also, when i do find the number. how do i read it.. like what does it mean.. or can i just ask here and someone will know.
Old Feb 13, 2003 | 12:27 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Check-out www.mortec.com it will have all the info needed.
Old Feb 13, 2003 | 05:23 PM
Car: 1984 Z28
what about numbers on a rear axel??? i found these on mine...
GM N
22522676 **
K8 A021
**= could also be the number 22522878
ive been trying to figure this out for a while and i am having problems.. thanks! ps. im pretty sure it is the stock axel.
Old Feb 13, 2003 | 06:53 PM
timtpi305's Avatar
the numbers on the axle is the axle code. that will tell you everything about the axle. tells you if its posi the rear gear ratio and what not.
Old Feb 13, 2003 | 07:14 PM
Car: 1984 Z28
yeah thats what im asking.... what is the ratio, etc...
Old Feb 13, 2003 | 08:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The number you posted is the casting number for the rear end housing. Not particularly informative. "Yes, this car has a rear end."
For rear ends, the best, actually the only reliable way of knowing for sure what you have, is to take off the cover and look. If you haven't changed the fluid lately, you need to take the cover off anyway; look at it while you're doing the overdue maintenance.
Old Feb 13, 2003 | 08:30 PM
Car: 1984 Z28
damnit... that is something i should have done when i bought the car... maybe ill just take it in and get them to do it... and the tranny fluid while they are at it.
Old Feb 14, 2003 | 01:50 PM
Pontiacman's Avatar
If it's original, bring you're vin # to the dealer and ask for a print out of the option codes at the parts desk. It will be listed on there.
Old Feb 15, 2003 | 02:07 PM
Car: 1984 Z28
good idea! im going to do that.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
