LT1 Computer Location
Old Feb 16, 2003 | 09:19 AM
ragtopcamaro's Avatar
I am trying to figure out the easiest place to put the computer. I see a few people talking about mounting past the firewall. Where are common locations with a stock wiring harness?
Thanks,
Gus
Old Feb 16, 2003 | 12:44 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Make a mounting plate and attach it on top of the strut mount. Easiest place I've seen. Or lengthen the harness and put it where it normally goes.....
Old Apr 7, 2003 | 04:30 AM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
ttt
Old Apr 7, 2003 | 07:31 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I'm not using the stock harness so not sure where that would go.. I am putting my puter tucked up under the drivers side cowl next to the brake booster.
Old Apr 7, 2003 | 01:35 PM
TexasLT1's Avatar
Car: '92 RS
I've got mine mounted on a plate on the top of the intake. no harness modifications needed
Old Apr 7, 2003 | 08:42 PM
Brendon's Avatar
anyone have any pictures im also in the process of doingthis swap and i dont know if i have enough length on the power wire to go to the kick panel. Thanks
Old Apr 8, 2003 | 03:30 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am mounting mine in the stock location for an Impalla SS which is the drivers side battery tray.
Old Apr 8, 2003 | 11:58 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Try this or go inside the car. If I did it agin I'd be puttin it inside where the stocker goes.
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Stryker412
Sep 7, 2015 09:11 AM
L0tuS
Sep 4, 2015 11:16 PM
tonys91rs
Sep 2, 2015 07:07 PM
