AFR Heads and valve clearance
Old 03-05-2003, 01:47 PM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
I need to know if anyone has had problems with valve clearance when using AFR 190, 68cc chambers with SLP or KB forged flat top pistons with valve reliefs. The cam I am looking at has .525 /.525 lift
Old 03-06-2003, 09:05 AM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
Somebody??? I know there are some of you that have these heads. I just want to know if you had any clearance problems.
Old 03-06-2003, 10:49 AM
kevinc's Avatar
Car: 1982 Z28
I'm running AFR 190 L98-angle plug heads, angle milled down to 58cc chamber size, with 0.525" lift HOT cam.
Pistons are Federal-Mogul flat-tops with 2 valve reliefs, part# is H631P. I measured clearance at max lift, don't have the numbers handy, but it was well outside the limit.
So...if your KB pistons' valve relief is anywhere near as deep as the FM pistons, should be no problem at all.
Old 03-06-2003, 12:02 PM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
Thanks for the help. My figures are that there won't be a problem as well but I am trying to avoid problems and additional cost.
Thanks again.
Old 03-06-2003, 12:34 PM
kevinc's Avatar
Car: 1982 Z28
Are you sure you want to go with 68cc chambers? I didn't see if you're planning on a blower or turbo...for NA that will really drop your compression.
Old 03-08-2003, 08:54 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
A better choice will be to use the 74cc heads w/ flattop pistons to keep your compression low, if you use the 68cc and flat top you will run a high compression and will linit the use of street gas or higher octane rating. You will need to check the valve to piston clearance after you mock the engine. Different engine will have different clearance depending on the gasket, deck height, and cam. You can use some modeling clay to check the clearance and spray a little WD-40 on the clay strips to keep them from sticking.
If you need more direction just let me knoe i have a few article on how to do this.
DTL504
Old 03-08-2003, 10:57 AM
kevinc's Avatar
Car: 1982 Z28
DTL504
58cc chambers, 2vr flat-tops, factory deck height, 11.2:1 calculated compression, and 89 octane gas for street use. The way to do it is to tune the spark map carefully and be willing to give up a few HP (but not likely as much as w/ 74cc heads and 9.x:1 compression) when running the 89 octane juice.
It really likes 93 octane and a few extra degrees of advance, can't wait to test with 100+ octane racing fuel this season.
I don't disagree w/ what you're saying, but I can tune chips and upgrade fuels much quicker than heads.
Old 03-10-2003, 02:29 PM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
I am aiming at 9.7:1 to 10.0:1 compression. I don't plan on a blower but may use a small shot of N20.
evilstuie
01-09-2020 08:29 PM
CRFred
02-07-2016 11:39 PM
LT1Formula
20
11-14-2015 12:02 AM
89mulletbird
08-12-2015 07:08 PM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: AFR Heads and valve clearance
