LT1 hot cam?
Old Mar 13, 2003 | 05:30 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
LT1 hot cam?
i called a company who builds factory replacement engines he said they have a cam upgrade for 50.00 bucs its a LT hot cam does the LT1 have a hot cam? and whats the stats on it if so?would it work well with the 350?
Old Mar 13, 2003 | 07:52 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
If it has the specs of this cam then it's a good cam.
http://www.sdpc2000.com/cart.asp?act...d=989&pid=1087
Old Mar 13, 2003 | 08:42 PM
v8unleashed's Avatar
what do they mean when they say....... "Computer modifications are usually required"
Old Mar 13, 2003 | 10:35 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
Reprogramming for optimum efficiency.
Old Mar 13, 2003 | 10:38 PM
1987gt's Avatar
Car: 1989 GTA
no he said it was a LT1 hot cam not LT4 is their a LT1 hot cam?
Old Mar 14, 2003 | 08:04 AM
Car: 87 Trans Am
I don't think there's an LT1 hot cam all I've heard about was the LT4 Hot Cam. You should call them up and get the specs of the cam.
Old Mar 14, 2003 | 10:01 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
First of all LT1 did not come with hot cam
Second of all there is a big diffrence if you buy you cam from GM or Comp cam or from that new company even if they are the same specs (Duration- lift) you will get diffrent HP reading... Why??
Because the way how they designed the lobe of the cam and how much they spend time on researching so be ware.
Ivan
Old Mar 14, 2003 | 10:05 PM
1987gt's Avatar
Car: 1989 GTA
i found out it was a stock LT1 cam.you mentioned those cam companys what cam is best?
Old Mar 17, 2003 | 12:51 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
honestly I do not witch cam is better you need find out how did this kinda cam swap but I would go with GM hot cam kit.
Old Mar 18, 2003 | 12:58 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
How much do you wanna spend and do you want to tune the car yourself?
I'd go with a Comp Cams 306. High lift with 1.5 rockers. Just need new springs to support the lift.
I've got an LT4 hotcam in my LT1 block so I am just going to use that for now.
Old Mar 18, 2003 | 08:36 PM
Momar's Avatar
I wouldnt go with the 306 with the stock replacement motor. It is a large cam and tends to give a little cam surge even with tuning on LT1's, and a lot without. This cam likes to rev to 6500. Can your motor take this?
With that mentioned, do you have any specs on the motor? What heads does it have(flow numbers?). Are you going to have headers and exhaust? What kind of fuel system are you going to be running. We will need to know all this before we can really give a good suggestion on the cam. LT1 heads tend to flow a bit better in stock form than most other heads and pretty much all thirdgen heads. If you are using stock unported heads I wouldnt go bigger than the LT4 hotcam.
If you go with an aftermarket cam, I would suggest Comp cams extreem energy line. It helps keep good drivability with larger cams by faster ramp rates on the cam. Many people have had good results with them.
Ben
Old Mar 19, 2003 | 10:22 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I agree with you
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
theurge
Aug 21, 2015 12:46 PM
