maf to sd which vss in T5
Old Mar 26, 2003 | 03:48 PM
PunishingGTA's Avatar
Car: 1987 GTA
Engine: Stealthram 355
Transmission: t5
I'm trying to figure out which vss I am suppose to use in my T5. I am converting over to speed density and had heard I needed to switch out my old vss for one for a sd car. The problem is that GM has two vss's for a '91 T5. I am assumming they are based on rear end gear ratio. I have an '87 GTA using a 9-bolt w/ 3.42 ratio. Do I really need to switch and if so which part # do I need to switch to?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
