engine too big
Old Mar 26, 2003 | 06:29 PM
jeffers42's Avatar
Car: 1985 camaro
Engine: 1971 355
Transmission: 5-speed
engine too big
well I have a problem
my engine swap from a v6 to an 8 is proceeding
my 350 has an edelbrock performer rpm and an edelbrock carb sitting on it with an aircleaner.
with all of it here the hood will not close.
i was considering a cowl induction hood but do not know what size and if one vendor is better than another
thanks
george jeffers
Old Mar 26, 2003 | 11:48 PM
9TEEN92Z's Avatar
go with a 2.5" cowl, looks bad ***. 4" is a little big and probably will restrict your vision looking across the hood.
Old Mar 27, 2003 | 07:30 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
What kinda base air cleaner are you using? And how much more do you need to get it to close. If you're using a flat base, you might wanna get a drop base air cleaner if you wanna be able to shut the hood before you can get another hood or a cowl. Also, if you're using a 3 inch tall filter, you could go down to a 2 inch tall one.
Tom
Old Mar 27, 2003 | 12:26 PM
Guest
Guest
Posts: n/a
I agree, try a different filter.
Old Mar 27, 2003 | 11:11 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
I had the same problem. There was no way around a cowl hood for me because the very top of the carb sat above the hoodline. If yours is the same, I'd recommend a 2" cowl. I bought a steel one from carhoods.com. It ended up costing 500 bucks with shipping. Fiberglass is cheaper, but in my opinion not worth it in the long run if you plan on having your car for a long time. You're only other option would be to buy a cowl to put on the hood you have now. I believe someone on this board did that and has pictures of what it looks like. It's the cheapest solution.
Old Mar 28, 2003 | 09:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
This is my old setup which is similiar to yours and my hood closed on my Trans Am,
Edelbrock 7101 Perfromer RPM Intake
Edelbrock 1406 Carb
Edelbrock 14x3 Drop Base Air cleaner
Orr89RocZ
Apr 25, 2016 08:28 AM
sreZ28
Aug 14, 2015 07:48 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
