ALDL Pin Out 95 LT1
ALDL Pin Out 95 LT1
I found a pin out at one time for the ALDL. However, now that I need it I can not find it again.
The '89 has a 12 pin ALDL. I plan to use this connector. Will that work considering some of the 95's I think were 16 pin. I think it would be fine.
The best information I have found is that pre 94 the Data Link lead should hook up to the M terminal of the ALDL. Chassis ground should hook up to the A terminal of the ALDL.
Any insight into pin locations or problems with using the 12 pin ALDL locations would be greatly appreciated.
Gus
Gus
yes, you can use the 16 pin connector from your car and simply repin it for the '95. try pm'ing Mat89rs, I know he has the pinouts for a bunch of different connectors, I think he has the one for the ALDL also.
88SS6SPEED
Nov 11, 2015 07:05 AM
